Tappet adjuster tool dominator 99 1961
Hi does anyone happen to know what size tool is required to adjust the tappet? Is it 5/16
​​​​​​ Thx
0.44 " ( 11.3 ) mm
That's 3/16" BSW or 1/4" BSF
... for a Triumph twin which uses a similar method. A short length of 1/2" diameter alloy rod drilled centrally (about 6mm IIRC) then a tapered square section drift hammered into it. Then knurled to make it look posh.
Actually just realised it was for a Honda but the same applies.
Here it is:
tappet tool
Assume it simply needs something to hold it still while the nut locks it up right?
Didn't the rear shocks adjuster spanner had a square hole?
