Sealing original scavenge pipe pickup 850
Hi all, the oil pump pick up point at the front of the t/s casing leaks air when i pressurise the rear pick up. It had been sealed with Araldite before, do we use the same again?
 Whats a plugged hole doing there? Has this been something done by a previous owner and bodged up? I would be tempted to remove the plug, tap out and screw in a better fitting plug ,sealed with loctite
