Morning all.
Has anyone out there got a spare pair of the separate frame braces that are fitted to the navigator deluxe that I could purchase? (I understand they are actually part of the frame for the standard).
Or even some I could borrow to get copies made.
thanks
Sholto
I haven't got a spare set…
Tubing will be aquired and…
Tubing will be aquired and heavy hammer put on stand by.
thanks
Sholto
Hello Sholto, I just happe…
Hello Sholto,
I just happen to be working on a De Luxe Jubilee so here are some approx measurements. I make the tube 3/4" outside diameter and the length 13" between. It's a bit awkward to measurement as the side cover bracket gets in the way. Here's a picture of the actual bracket. You may already know all this.
p7270093-jpg
And here is a picture of t…
And here is a picture of the frame tube.
p7270092-jpg
Previously sholto_humphrie…
Previously sholto_humphries wrote:
Morning all.
thanks
Sholto
Hi Sholto,
Send me your email and I will send a couple of drawings over that may help, one is just over 1MB so I cannot attach.
Previously Tony Ripley wro…
Morning all.
thanks
Sholto
Hi Sholto,
Did you get my email?
Sholto
Patrick Thanks for the pho…
Patrick
Thanks for the photos.
Very usefull.
Sholto
I haven't got a spare set of these and they do seem to be missing on virtually all De Luxe frames you see. They will be easy to make as you only need to weld a bracket on a tube to accept the dzus fastener spring, cut the tube to length, flatten the ends and drill two holes. If you use your own side panels as templates to locate the dzus fastener then you know that the fastener will fit. I have found a few of these braces at auto jumbles in the past but invariably they needed some adjustment to make fit-i.e a few clouts with the big hammer.
Don't forget when making that they are handed.
Patrick
