Hello all, finally got a Norton back in my garage a 1962 99, rideable but due for some TLC. The left pipe is a lot bluer than right was going to check timing as I believe the camring is not always 180 deg apart and that cylinder may be retarded, any errors to be ‘shared’ to avoid stoning of cam ring? Pipes are stainless steel so chrome variations can be ruled out and it is single carb. Tappets are ok too. Bike is easy starter and rides well after I replaced caps, leads and mag pickups. I have noticed the LH plug is fired by the mag output nearest to the cylinder, understand that normal practice is to use the other output? Not sure if this makes any difference? . Only worked on singles before. Any comments appreciated thanks
Pete
Peter...yesterday there were…
Sorry yes I accidentally…
Sorry yes I accidentally posted in light twins forum thanks for info though
left hand or drive side ignition
hello your motorcycle a Norton Model 99 should be on coil ignition and the left hand cylinder should be set up with ignition lead the farthest way from from the rear of cylinders And remember a four stroke engine fires once ever 720 degrees so a twin fire only once ever 360 and the timing runs backwards to the engine on the timing side and distributor cams can get worn at one side more then the other side and can be out as much as 8% so you need to re-check the timing with a good alloy timing disc and a good timing light with the pointer fixed to the rear cylinder barrel stud and you need to rocker covers removed to see that at tdc you have all the valves are in closed position then you can start you timing and you distributor rotor should b pointing to the oil tank and battery box for the left hand cylinder now most members will say this makes no difference but I have found over the 52 years of owners ship of a number of Norton twins this dose make a difference as ignition cams can be out even new ones can be out now all the best yours anna j
magneto
hello the Model 99 were coil ignition from September 1957 to october 1962 when bracebridge street workshops closed and that was the end of the Model 99 along with others the only time the factory fitted magnetos on the model 99 was from september 1955 to 1957 from september 1957 the alternators where fitted and so was the coil ignition system with the prs8 ignition and lighting switch and d2 distributor as standard and nothing was changed in 1962 until closure in october of that year and the only new machine for that year was the export Atlas 750 yours anna j
If it has a magneto..
... and the owner is happy with it, who cares what it left the factory with? (a rhetorical question as I think I know the answer.....)?
Peter...yesterday there were at least two comments here...did you see them? If you deleted your own question to rephrase it, they probably went also.
I'd first try measuring how hot each pipe is on tickover when it is retarded most. Maybe the previous owner fixed it before you. You can buy cheap infrared thermometers. Handy in the house when cooking the turkey, or checking the freezer.
Don't swap the leads. Waste of effort unless you are fanatical about original appearance.
But then it has to be worth checking for equal opening angles. But I don't know acceptable tolerance...one or two degrees maybe?
