i have a 850 commando i see on ebay you can buy a 34mm carb kit it say.s for 750 or 850 commandos i though the 850 needs the 36 mm mikuni carb but im not too sure
Hi Shawn, I have an 850 Mk…
Previously wrote: Hi Shawn…
Hi Shawn,
I have an 850 MkIII fitted with asingle34mm Amal Mk2 (The Mikuni is alicensedcopy of the Amal) and this is perfect. I think the 36mm will cause you problems.
ok thanks for that tony
Hi Shawn,
I would check out below an…
I would check out below and avoid the risk of ebay....
Hi Shawn,
