Jubilee frame question
Should the jubilee have spacers on the top and bottom frame bolts...the bolts that attach the front down member to the frame rails?
The spacers are there as the frame is basically a Francis Barnett Cruiser 80 frame - but the Jubilee engine is wider.
So beware also if buying a Hex footrest bar & Swing arm that look the same as your items, but may actually be norrower.
See Frame picture attached - the spacers are item 10
frame-d-lux1-jpg
