Cannot see any reference in my manual for oil amount and type for the Jubilee chaincae/clutch housing.
What amount and type does the Jubilee require.
John.
Use normal engine oil. I u…
Previously patrick_mullen…
Use normal engine oil. I use 20/50. Pour the oil in through the top inspection hole until it drips out at the level plug then tighten up both top and bottom plugs/covers. It takes very little oil but I can't remember how much. The chaincase is virtually guaranteed to leak so check oil often.
Thanks Patrick.
Is the bottom screw plug the level plug. Looks a bit high for a drain off.
John
Yes it is. It has a slot h…
Yes it is. It has a slot head so tighten with a screwdriver.
