Commando wiring
According to my factory notes aBrown Blue lead comes from the negative battery terminal to the centre blade of therectifier then on to the Zener, capacitor and master switch in that order.
HOWEVER my 1974 850 [currently bought as a non runner] has the Brown Blue lead going fromone of the outer blades on the rectifier to the Zener.
The Brown Blue battery negative is wired as above and in accordance with the wiring diagram.
Any ideas which is correct, I cannot believe it does not matter.
Many thanks Roger
Previously david_evans wrote:
The two wires from the alternator go to the outer terminals of the rectifier. This is the AC in. The center terminal is the DC out and should be connected to the battery, zener and master switch. It is normally Brown/Blue. (I'm presuming a standard black finned rectifier)
Thanks David. However there are other problems,I am comparingmy bike with the wiring diagram in the factory notes, 1972 onwards. TheBrown Blue does go to the battery then the capacitor then master switch BUTBYPASSESthe Zenner. There aretwo Zenners fitted, one off each pillion hanger bracket, thetiming side zenner has a white green taken from one of the outer black finned rectifier terminals, through the zenner to earth. The drive side zenner is greenyellow from the other outer rectifierterminal through the zenner to earth. The circuit diagram only shows one zenner with the BrownBlue leads coming from battery to thecentre rectifier terminal, zenner, capacitor then master switch. The white green from the alternator does not go beyond the rectiifer, according to the diagram. Obviously I canre-wireas per the diagram but wonder how the bike got in this way.
Many thanks again for your comments. Roger
Sounds like someone has fitted the MK3 uprated alternator and also fitted the matched pair zeners as the output exceeds the capacity of a single Zener, so you will need to look at the MK3 wiring diagram for the charging circuit and then try to see how it compares to yours.
Hi John and thanks. My alternator only has two wires, does that sound like Mk3?
My Factory notes [and Haynes Manual] do not mentiona Mk3 wiring diagram. The latest diagram mentioned says NORTON COMMANDO 1972 [ALL MODELS].
Is there another wiring diagram somewhere?Are there later factory notes? Where will I find Mk3 wiring diagram?
Thanks again Roger
The Mk 3 has a single phase alternator to the best of my knowledge so two wires would be correct. (three phase would be three wires) I thought that the Mk 3 utilised the two matched zenners as a half of the wheatstone bridge (rectifier) not sure what forms the other two diodes. To be honest I would treat yourself to a modern regulator rectifier unit as sold by Paul Goff or a Boyer Power Box. Zeners and rectifiers are dark age stuff now, unless you want to keep that original look. I presume you bought the bike to ride not look at so a proper workshop manual from Andover Norton would be money well spent.
Al Oz and Goffy sell an excellent modern single phase rectifier, does away with the Zeners, it's also easy to mount being smaller than the podtronics unit. Coupled with a BSM (Battery Status Monitor) you can disconnect the warning light assimilator and have less wires, less connections, less loss and thus more confidence in what your charging circuit is doing. I have done this upgrade in the past year and wish I had done ages ago to my MK3 as it highlighted that the old wiring in the charging and control circuit was past its sell by date.
Thanks everyone for your helpful comments. I have been away from bikes for a while so not familiar with latest developments. Do you suggest a single phase regulatorAND a Boyer Power box or just one or the other? If I have the power box does that mean I do not need a battery?
David, It was bought to ride but it might be a while bearing in mind it's condition.
Thanks again. Roger
The MK3 wiring diagram is in the back of Haynes in the MK3 supplement unless you have a very old version. Whatever replaces the zeners will need to handle the max output of the MK3 alternator which probably rules out the Powerbox. If the zeners work then keep them.
There are a number of 'misnomers' in this thread but the most are in this post. The Zeners are NOT matched when used with the high output MK3 Commandos (and JPN) The matched Zeners were only used in parallel with the high output three phase system as sold by Mistarl engineering (several years ago). The traditional bridge rectifier is not a 'wheatstone' bridge, either. The Boyer power box will handle theoutput from the single phase RM23 (as used on MKIII Com.). Rectifiers and Zeners are no more 'dark age' devices than these 40 year old machines. There are a couple snags with Zeners-they can have high or low voltage-a high one will give you a 'well' charged battery, a low one will give the symptons of 'no charge' Zeners are becoming scarcer and expensive, and their wiring is a little more messy than a modern recg/rect. A basic single Zener system in working order has no issues, leave it alone.
One small area where the RM23 high output (MKIII Com) system using two Zeners (on the alternator side) is at a disadvantage is that this system does run at a slightly lower voltage than would be prefered (due to the natue of the Zeners being part of the bridge) in this case, especially as the MKIII needs all the battery capability you can get, it would be worth converting to a reg/rect.
By the way 3 wires does NOT mean three phase, the RM19 (6V or 12V) has three wires. 9 pole pieces means three phase. ( I even used to sell a version of the RM23 single phase high ouput alt. with three wires at one time-yes the wires were GRN/YLW-GRN/BLK-WHT/GRN. I think Lucas had the worlds supply of these wires)
Al Osborn.
