cam bush left side how to remove out of case
what is the best way to remove the cam bush out of the left case
hello the best way to remove bronze cam bushies  is to bung the cases in the oven and put in on full for 20 minutes  to half-hour and have a set of leather gloves and a good wooden board when hot just light drop on the board  and they should just drop out  and you fit them the same way but making sure you have the oil holes all lined up,   the job that simple  but do not let the wife catch you,
   yours  anna j
Maybe the trick with s big tap, used by Mick Hemmings in his gearbox video, combined with the oven?
Trying to cool the bushing? Though you might not have a bucket of liquid nitrogen.
If the Bush were steel then the heating would work, but bronze is nearer to aluminium in expansion rate hence why the bronze exhaust nuts work better than steel ones. The big tap plus heat will work.
