Norton 16h wd restoration
Hi all, looking for some advice please. My brother in law and I are restoring a 16h that he purchased some 35 yrs ago but never got round to doing anything with. The problem we have is the frame number has been removed with only w45 remaining the frame was checked by an expert to see if the could find any imprint of original number without success but they said frame was definitely wd 16h, The engine number has been changed as well and stamped W96332 and has a shop number stamped on the front of crankcase A995 which according to NOC refers back to a 1946 model 18 which was an overhead valve. The advice we have been given is to go ahead and complete the rebuild and the NOC will try to get an age related registration using what there is of the frame number. Now I can buy a crankcase with a genuine number stamp which dates to 1937 but doesn't have the W prefix. The question is would we be better sticking with what we have or buy other crankcase and use that engine number as a reference, thankyou and sorry for the long winded story. Ron Beaton
It is regrettably a problem with WD16Hs that whilst there was little incentive during wartime to re-stamp numbers, it seems to have become common practice as part of the military rebuilds during the 1950s to do just this, so that rebuilt machines continued to reflect the inventory.
DVLA are aware that not only did the Ministry of Supply allow the re-stamping of service vehicle numbers, but they also subsequently permitted the sale of these altered vehicles to unsuspecting members of the public, with proceeds to Government coffers...
There can never be guarantees, but based on previous applications, providing that you're building a true reflection of a 1940s Norton, it should be possible to obtain an age-related number. There is the possible risk that DVLA may require to stamp a 17-digit VIN.
There are no surviving late-war factory records but the "shop" number system of an alpha and up to four numerics was commenced in wartime so it's quite likely that they started at A101 and that this occurred again in 1946 with the civilian engines. It's only a factory build identifier so no problem if the number came around again a few years later. Obviously, it's quite easy to differentiate 1936-pattern WD16H crankcases from the 1938 civilian type used again from 1946, not least as cylinder stud spacing altered. They're fairly different castings when compared closely
Thank you Richard for your reply that helps a lot, we will just go with what we have got and try to complete the build. Thanks again
Hi Ron,
   Richard Payne is the "go to guy" for WD information, but for registration help you need to speak to Chris Streather listed in the contacts in Roadholder. The engine number is not so important, as long as the engine is a similar type to the original, and engines were changed on a regular basis on many bikes back in the day as it was a cheap option for private owners. The DVLA will, rightly, regard the frame number as the vehicle identifier as the chassis is the basis of the machine, whereas the engine, gearbox etc are liable to wear/fail with high mileage. Speak to Chris about the frame number problem before getting too deep in the restoration.
In reply to by richard_cornish
Richard, I assumed from the way Ron worded his post that he had already started the process with the Club Records Officer and that quite probably the bike had already been examined.
https://www.wdnorton.nl
Also, I found Rob in the Netherlands a very interesting man on WD 16 h's.
He was able to tell me that my cutaway was between contracts.
Rob has all the numbers detail, except for the above..........
Just some additional info, that's all.
Thank you everyone for your comments, we're learning something new everyday about these 16h machines. And please be aware I'm sure there will be a lot more questions to come. Thanks again.
The website encountered an unexpected error. Please try again later.
