frame es2 rigid ? year interesting stamping
Hi i have what i believe is a rigid es2 cradle frame. under the downtube support it is stated as a N4 and on the other side is a 4 digit number in the late 6000"s - 6 9_ _ .  I would anybody have a clearer idea of the year?. I have been working on the idea that it is pre 1939
A strange thing about the frame is on the headstock on the curved plate it is also stamped. This looks more modern stamped number  (not cast). This stamp is 10 446 M__. so 5 numbers and  3 letters in small stamping.
What is the significance of this ?
Any answers greatly received thanks Mick
The ES2 was always to a higher spec than the rest of the OHV range. Pre-war, this meant a cradle fame. After the war, the Model 18 gained a cradle too and the ES2 became a plunger-sprung model.
If a rigid cradle frame has a number as low as 6000-odd then it is a post-war Model 18. It was normal practice for frames to have a factory 'shop' number that aided tracking it through the assembly process prior to the end of the line where engine and frame numbers were stamped.
It's difficult to say without photos but this may be what you're seeing. Unlike the shop engine numbers though, on the frames they were usually solely numeric.
Have a word with the club records officer. Both 'matching' frame number and shop number are normally shown in the factory records.
Thanks for the response ill take a photo of the smaller stamping and add , I was under the impression the N4 stamp correlated with the es2 but that could be my misunderstanding. Cheers Mick
It's a casting mark. M&B were the foundry. Mason & Burns of Walsall who made malleable iron castings for most of the British motorcycle industry.
Hi Mick,
   The number shown in your photo is the the casting reference number and the M & B will be the foundry that cast them. The N4 on the other side is a general reference number used on most externally sourced parts. The frame number should be on the nearside of the front petrol tank lug. If you want to send photos of each side of the full frame, I can give you a visual identification.
P.S.  The other Richard posted at the same moment as me, hence the cross-over.
Richard, it's not very often that we disagree, mostly just a question of who gets there first. :-)
Thank you o you oth , i have attached a pic of the frame number not sure if its quite clear enough but its 6996 otherside
That really looks like a casting mark. Have you had a good look at the front nearside fuel tank mount ?
Hi Richard ,  I eventually found 57314 on the nearside further up the frame near the head stock. Does this provide any further clarity on age ?
Thanks for your help a brighter light helped along with a change of glasses
cheers mick
Hi Mick,
   This number could apply to a 1934 or a 1954 bike, but to get an idea you need to post a photo of the whole frame. If you would rather not do this you will have to contact the machine registrar as he can then check your number in the factory records, although he will probably want photos as well. I have attached 2 photos, the first is the 1930s type and the second is the 1950s version.
Hi Richard ,
apologies for late reply but my frame is identical to the second image img_1581. Thanks for the information. As a 1954 frame which model would it be  ? model 18 last year  ?
thanks Mick
Hi Mick,
   There should be another letter and number stamped near the 57314. For 1954 the year code is J, so if it is a Model 18, it will be J3 as the 3 denotes the Model 18. It could also be a 16H which will be J2 or a Big4 which will be J7. All these frames will be identical.
   Although several of the lugs differ from the pre-war version, the main change are the gearbox lugs. The pre-war has the upright "doll's head" box, while yours will be the laydown pre AMC type.
I have got three  model 18s all rigid and one plunger ES2 frame.The 18s are 1946,1947,and 1949 with upright gear boxes the ES2 frame is 1954 with a laydown box all four frames have the frame no and year letter stamped on the front down tube sidecar lug but there again you may have a special my first 18,a 1946 model, (gone many years ago) had a plunger frame upright gearbox and girder forks.all the best
Hi Richard and Gwilym,
thanks for the info but I can’t find a model code. I have attached a photo of the frame number a rechecked against the photos offered and it is identical to the 54 frame.
thanks again mick
I attached an edit of Richard’s frame photo where probable frame serial number and model code would be stamped(opposite side of the lug that we are viewing in picture). In general, did this era frame have multiple locations that the frame number could be in or was it one location?  Any insight is appreciated as I was under impression that there was only one location for the stamping from factory. Thank you -Pat
If you go onto andy buys bikes website he has got close up photos of frame and engine no  locations he hasnt got any singles for sale but if you go into the archive/bikes sold section and scroll down ( a long job) you will find a no of singles click on any and photos of the locations will appear hope this helps
And show the full frame, one (or more) of the crew will tell you what the frame is whatever numbers are hammered into it.
The frame is the type used for the post 1950 single models as it has the  castings to mount the laydown gearbox.
As Richard Cornish has previously posted, the frame is for a 1954 rigid single.
The number would date it as a January or February despatch.
Richard has documented the models. There should be a letter J stamped above the frame number and a number to designate the model.
There are instances of the letter not being stamped but you should be able to find the model number.
2 for a 16H s.v.
3 for a Model 18 s.v.
7 for a Big 4 s.v.
There were also a few rigid framed Model 19's made at this time.  These were designated with a model number 6.
thanks for the information, next stage going to get shot blasted so hopefully will reveal numbers further i hope.
Mick
57314 falls within a large batch of Model 7, Model 88 and ES2 bikes all produced in the first week of April 1954. These bikes are all recorded with the Model Mumber 'J'. Is this the correct frame number?
hi Philip, this is the only frame number on the bike, planning to have lightly blasted and will give it another good look over for any other numbers but it does appear to be the only number. there are several casting numbers and even the first cast number i showed.
This frame had been left on a farm in yorkshire along with a collection of wheels. an old ariel and bsa b31 all at some point used by the previous owner. these had been left for at least 45 years.
I have a commando i had restored and left this frame in my loft for 10 years but i am keen to start accumulating the right bits for the bike, this is why i was seeking the guidance
and that s why the pictures are taken in my loft.
I know for a fact the bsa and the ariel had been used in very early local trials. But the owner had moved onto scramblers.
I feel this may have been one of his many road bikes at some point.
any help gladly appreciated  Mick
The website encountered an unexpected error. Please try again later.
