Mikuni choke
I have a 750 commando fitted with a Mikuni with the choke lever on the side of the carb. I havn't had the bike long and cannot get it to start, can anyone advise if I press down on the lever or lift it up to put the choke on?
Gary
On every choke that I have come across its push it down for choke on, lift it up for normal running.
If it's a proper lever push down for choke on , if it's a push pull type pull for choke on.
Previously alan_johnson wrote:
My sentiments entirely ,nothing wrong with an Amal MK 2
Or even a Mk 1, Alan...
Hi Gary
You push it down but they are either on or off, its very difficult to get an in between. Mikuni do a cable conversion for it which will give you a more accurate choke.
Guy
Gary
A SU carburettor would be better that do a conversion kit contact Amal& SU .co.uk
Many thanks everyone for your comments. As I can't get the bike to start at least it gives me a starting point.
Hi Gary
I'm using a VM36 mikuni on my 850, works fine now, but it was a cow to start before I sorted out a techique
The choke lever( its a starter system) is pushed down,this allows a metered amount of fuel into the starting system,You must have the throttle shut as this effects operation of the starter system
I'd advise you to download the Mikuni Vm Carburetor super tuning manual (from Allens performance or from Motocarb) pdf for free
vmmanual.pdf
My Technique is fuel on/ ignition off and check the clutch is nice and free,clutch out then push through two or three times with a little throttle basically to draw some fuel into the carb (if its been standing for a week or so) then choke(starter) lever on ignition on the bike normally starts first kick,as soon as it has I catch-it on the throttle and shut the choke off,I normally give the throttle stop screw half a turn in to keep the revs up until she settles to a steady but fast tick over,this can be altered by hand whilst on the move,You can start the bike in the normal way after a short stop for tea or a pie n mash,no choke, little throttle, big kick,good luck.
steve
Thanks Steve - Really helpfull. Mine had been laid up for a few weeks. I'll try what yo suggest, It had wet sumped but I've drained and refilled it.
I agree with Steve. i have the same carb on a 72 750 and the knack is NO throttle on start up from cold.
Mark.
