All Forum Posts
Breather question
I'm planning on fitting a one way valve from the timing case breather pipe to the oil tank inlet up at the cap. I have a Mk.3, but I'm changing the black box to a slim ham can.
clutch basket
Hello new to this forum looking for a bit off information regarding clutch basket hitting back off casing when tightened up is there a spacer between basket and oil seal on shaft
Mikuni problem
I am in need of a new float arm for my VM30 Mikuni carb but neither Allen's Performance or Motocarb are answering either emails or phones - except to tell you by recorded message to email them!
Speedometer twitch
Investigating the reason for my speedometer needle twitch and intermittent drop to 0mph, I found the rear hub cracked at the speedometer drive collar left hand threads, the drive collar spinning in the damaged thread during drive causing the issue
Tapppets
When replacing the cylinder head it is fiddly to get & keep all rocker ball-ends in the pushrod sockets.
500 twin crank survey
if anyone's got a 500 twin crank in bits would you be able to measure the oilways inside the crank? should be either 1", 7/8" or 5/8". It would be good to know if it's a dynamo crank, alternator crank,SS crank....
