Electra prop stand fitment
I've ordered a prop stand, stud 22610 and centre stand from the Club shop. Does anyone have a photo of how the prop stand is fitted? Is the stud the lower or upper one at the lower end of the downtube? I assume it's longer than the standard one to allow for the bracket.
... that does explain and gives me something to look out for. I see I even contributed something to the thread myself! I was hoping for a simple fit-and-forget solution. When the stand arrives I'll check out the points made.
... and others have given me much food for thought. What a great resource this forum is.
.. I bit the bullet and ordered both a prop and centre stand from the NOC shop. Unfortunately I'm disappointed in both and will be returning them.
The centre stand is defective in that when the lifting arm contacts the ground, the stand itself is in an almost vertical position. This would mean that any slight push from the rear would cause the stand to retract and the bike to fall over. This is clearly either a design or manufacturing fault.
centre stand
With respect to the prop stand, the section that abuts the frame tube has obviously been poorly cast and an attempt has been made to repair this with weld. As this portion is crucial in maintaining the angle of the stand it’s again unusable.
prop stand
In that thread (or another, my mind is going), there is mention of a spacer between the flattened frame tube and the downtube which is replaced by the Kawasaki mounting plate. My frame does not seem to have such a spacer. Is this an Electra quirk? I haven't loosened the nut so don't know whether the frame tube will spring out to give me that clearance. Otherwise I could mount the stand on the outside of the flattened portion.
frame
This is the picture set showing the spacer.
Navigator sidestand
Ian,
Your electra should have a pair of these between the flat frame sides and the lower front frame section.
Navigator and Jubilee have another four 21102 between flat frame sides and upper front frame section. (2studs).
Electra has reinforcing plates. The four spacers at upper front frame section are thinner, and go outside the reinforcing plates. Total thickness, same as 21102 spacers.
I live near Skipton. Are you near me?
Parts list for Electra is very useful.
... I actually think you know the bike, I bought it from Andrew Sharp a couple of weeks ago. I wonder why my bike doesn't have the spacers - I need to take the tank off and see what's at the top end. I am a bit concerned that the lower tubes have been persuaded into position, although the stud doesn't look long enough to allow for the spacers. I've got the longer stud anyway and it's easy for me to make whatever I need.
At the moment I'm just looking it over and seeing what it needs but I'm so far very pleased with what I see. Given it's been laid up for a long time it's in very nice condition but is missing the prop stand and the centre stand takes more than my ageing muscles to operate as it doesn't have the curved foot arm.
