Having just spent over £1K on getting my 1963 Norton 650 SS running from a business in Walsall area
Got the Norton back home last Tuesday, After getting the rear brake & other details sorted I rode the Norton approx 5 miles on Friday Morning. After stopping at a petrol station put 4 star fuel in on the A45 where I live near in the Northampton Area I turned the opposite way on the A45 just past the opposite Petrol station on the A45 the motorcycle broke down. I pushed the beast back to a Car park of the A45 & got the Norton recovered to my garage by Friday Lunch time.
If you have read this & are with me The main reason I post is a important question I have:
Having removed the right timing chain cover. I have noticed the when the half time pinion is at TDC. & The double gear above is at B.D.C. the gear that carries the Magneto & camshaft chains.
These two gears that drive the oil pump are very important.
It is noticeable that these two gears are not fully meshing a slight gap. This what failed causing the engine to be unable to be restarted. One of the gears had jumped two teeth out of sync.
The only way I can think of a way forward, is obtaining the bottom half time pinion gear as slightly over size in diameter. Is such a gear available or does anyone know of an engineering company that could make a slightly larger gear in diameter.
Both these gears are new having failed previously. The business that worked on the motorbike stated they have never seen these gears fail before. It now seems I have found the cause of these gear failures.
Can anyone help or seen this failures? Thanks
Regards John
2nd pair of eyes?
Norton 650 SS
I have posted a picture of the failed gears jpeg files if it helps
John
Norton 650 SS
I posted pictures of the failed gears in jpeg format if it helps
John
Four suggestions to inspect…
Four suggestions to inspect.
Was the hexagon nut loose on the crankshaft? (The lower, smaller, gear).
Or was the bush inside the upper (larger) gear worn so badly that it wobbled on its shaft?
The upper gear has a hardened washer behind it. Its shaft is intended to be tight in the crankcase but it often spins. Has it actually worn the case to an over size hole?
If the shaft is loose, it can easily come out when the timing case is removed. Then the washer behind the upper gear can fall down behind the lower gear. It that went unnoticed, it might well jam something. The shaft can be Loctited back in. There is a correct top and bottom. Its been discussed before here (which way round it goes).
Norton 650 SS
The shaft does not move left or right or up or down
will have to remove all gears & chains The washer is on the outside of the upper double gear
should that be crank case side?
regards
John
Hardened washer goes against…
My hardened washer goes against the case behind the big gear. So it goes onto the shaft before the big gear goes on.
The smaller gear has teeth stripped as if it was stuck on one place. But that's very odd since that is keyed to the crankshaft end, so that's the gear that should be turning, and the other one stripped. Unless the small one is simply not hardened enough...
The big one has one visible broken tooth. Is there damage elsewhere? If so, perhaps the broken tooth was where it was jammed by a foreign object, and the other damage location was where it ripped the teeth off the small gear when it suddenly stopped spinning.
Toothless
Note that the inner sprocket is missing most of the tops of the teeth. This is the chain that drives the magneto. The damage looks fresh and is possibly the reason for the crankshaft pinion carnage. This kind of damage occurs when a timing chain is set far too tight.
I am afraid that to sort this mess out is going to require a complete engine strip and clean.
outer sprocket?
Notice in the pix above, the twin chain outer sprocket teeth are at a needle point and the chain roller cavity seems exceptionally wide as if the cam chain ran incredibly loose.
The pix below is for a almost "as new" sprocket. Note square tips.
added
A very loose cam chain would cause a cyclic chain snatch when the valve goes over the top of a lobe, since the 22 lb flywheel is relatively immoveable. The sprocket and gear would suffer under the severe pounding by the valve spring in an unrestrained fall.
more sprockets
Found several more sprocket samples. It seems depending on the era of the engine the teeth shapes vary.
3 had the squared off teeth and 2 were pointy. Have 3 more twin chain engines but I was not going to pull the covers off.
9451X Manxman is pointy
I was fairly sure the points…
I was fairly sure the points on mine are quite sharp. A quick Google images search for images of 'Norton timing gears' confirms that sharp points are common on new ones. That alone wouldn't worry me.
But whatever the exact cause, it does look like an assembly problem unless the crankcases were wrongly machined. Washer in the wrong place and/or chains too slack and/or chains too tight and/or a mixture with one tight and one slack...
And as Phil says - unfortunately there might be bits of broken steel almost anywhere, including scavenged up into the oil pump. Although the gauze filter in the sump plug should stop the bigger bits going into the pump.
hello is everything…
hello
is everything accounted for ,
. woodruff keys,
. thick triangle washer and thin shield washer behind crank pinion.
. thrust washer behind double cogs
. circlip , bolts ect.
strange its happened before .with the gap in teeth on the cogs. could the crank shaft that side be bent . causing a gap then closeing up as it rotates ,putting strain on the teeth meshing. what about valve timing and pistons condition. what with the damage. how far has it gone.
Barry
Hi John,
I too live in Northampton and have a 650 too.
If you want a 2nd pair of eyes to look over your issue then I would be more than happy to have a look with you.
If you wish me to, Pm me.
Regards,
George
PS: Northants and Leics section meetings are not far away to meet up with other owners.
