The Magnetto on my project 88 as far as I know last run in 1988, would it be possible for it to work? on stripping the machine lot of engine work seems to have been done, but I feel it has never been started as combustion chamber clean as clean. any help on this please.
Not run is a bit of a…
The key to reliable starting…
The key to reliable starting is a good magneto.
I always get an expert to check over a magneto before using it on a rebuild.
You may be lucky, but I…
You may be lucky, but I wouldn't put money on it. Remember that just because a magneto can generate a spark in open air when motored that doesn't mean it will perform the same trick when subjected to a fuel-soaked atmosphere at combustion chamber pressures.
There are a number of magneto specialists out there, but I can recommend Peter de Kremer (Rutland Dynamos: http://www.rutlanddynamos.co.uk). Peter is a friendly guy and offers excellent after-sales service; he gave me a very helpful telephone refresher on techniques for finding t.d.c.
Oakham , in Rutland.
He did two k2fc’s for me last year. Beautiful work and exactly 180 degree separation.
cheers
Not run is a bit of a warning. Probably would not run. Could be any number of silly issues. Mag is easy to do a basic check for spark. 50/50 on whether it needs professional attention.
