The late John Hudson Tech Articles
I was searching around for technical information and read that the Late "John Hudson" had written some very informative articles regarding the Dominator engine with particular regard to oil pumps, supposedly there is even a video he put together as well?
Would appreciate it if someone could steer me towards this information please. Very much obliged...Thanks....Les
John made tapes on the engine and gearbox and several multiple page articles on stripping and rebuilding . There was a particularly good article in Motorcycle Mechanics, every time I read it I find something else . He also had an almost photographic memory. His methods of working were finely honed in doing what was needed in cramped damp dark sheds all over the country with no facilities and few tools, helping Joe public. He also Knew how to make an 88 fly. Just one of his interests. Wish I had been there to help him when he needed it .RIP John.
Thanks very much Robert for confirming the existence of John's write ups and films, it seems his efforts were very well thought of and worthwhile. I would have imagined the club would have with John's permission put them into a technical Archive (do we even have one??)...I would appreciate any further information of any write ups etc. made by himand indeed any stories of the man himself. I have quite a few old issues of motorcycle Mechanics, it would be nice to know what the date of the issue was thatyou mentioned above Robert...hopefully I might have it...BTW Have the films/videos been put onto YouTube?....I guess they are too long perhaps?....Perhaps someone could make up some on DVD format?
Any further info would be very much appreciated....Les
I have John's tapes which need to be transfered into disc's to be any use. I will look for the article . I spent an afternoon with John on a train and he was good company. He helped me with advice on a few occasions and sold me some bits thro the post. I would think the club could transfer the tapes and sell them to members. He was one of the good bloke's and his legasy should be continued .
I can remember two Norton video tapes, made by John, both involving engine and gearbox refurbishment. I am sure that, at one time,these were available in DVD format as well as video tape.
The out-takes were priceless and would make a great programme on their own. John frequently started to work on a part of an engine and would then suddenly walk off the set to get a special tool. There were three incidents that I recall happening which raised a few eyebrows.
These included him firing up his 1939 petrol powered blow-torch and then setting it down facing the backing scenery. If you look carefully at the video can just see it is pointing directly at a Norton calendar which rapidly begins to cook and curl its pages. The remainder of this part of the video had to be deleted due to the noise of the torch drowning his voice and the scenery starting to blaze..
Later, he then used the same torch to warm a crankcase half in order to remove a main bearing. When John believed that the case was sufficiently warmed he picked it up and dropped it onto a wooden board to release the bearing. Apart from a loud bang, nothing happened. So there was more warming and another drop. Still no effect apart from another bang. After another 6 more of these actions the drops turned into throws, which finally did the trick.
The third memorable scene involved John inspection a Norton crankshaft. Which he then placed on the bench before heading off-camera to get a caliper. As the bench was not level you can guess what happened next? Again the beginning of this mistake can just be seen in the video.
I tried very hard, in 2000, to get John nominated for an MBE for his services to both the Factory and the NOC but could not raise enough signatures. Can you believe that?
Thanks very much Phil...I had never heard of "British Bike Mechanics" mag before, but checked on Ebay and there are quite a few for sale so I'll look out for that copy and buy one when one turns up. As for the films I'm sure they would sell, they sound very entertaining with a lot of humour as well as beinginformative,
So Robert as you have a copy of them I wonder if someone could transfer them from the VHS medium (I presume?)to DVD? I'm sure they would benefit the club, but I'm not going to suggest any more than that as they belong to you and you must do as feel what is right and what you are able to. Perhaps a trusted member might be able to do the conversion for no charge...see what you think but whatever thanks to you both for giving us some idea of the man, as up to now, I had never heard of him and feel I've missed out by not knowingJohn Hudson whowas obviously quite some motorcycle mechanic and a great character too....Best regards...Les
I have the John Hudson VHS tapes, one on twin engine strip and one on gearbox strip, both NOC publications, dated 1994 & 1995. As you mention Phil, they are quite hilarious at times!
I am a bit surprised that the NOC did not carry these over onto dvd, and continue to sell them, as they are timeless, and there will always be a demand for them.
I am not sure where one stands on copyright where transferring them onto dvd and flogging them off is concerned. I guess the NOC holds the copyright to them. It would not take too much for the club to get a few churned out for sale to the members, one would have thought.
I recall the John Hudson VHS tapes were on sale through the NOCShop up to about three or four years ago and at the same time as the later excellent Hemmings and Pemberton DVDs which I have. Unfortunately I failed to acquire the Hudson ones at the time but would welcome the oportunity to do so now if made avilable again, either as VHS or DVDs.
I understand that the recently suspended AJD was wrapped over the knuckles for making copies of certain NOC property and then giving them away. Best to check the rules and regs of the Club first otherwise you may be joining her.
Can't beat a good naming and shaming!!!
I have the Hemmings dvd too, very good.
Hopefully those in the club hierarchy who hold sway on these matters will pick this up, and arrange for a run of each on dvd to be produced.
Erm.... 'club related and non technical items should be put in'News and Views''......
Or is that just for us mortals?
Just thought it was unnecessary to 'name and shame' (with apparent delight?) another member when they're in no position to respond....... That to me has little 'technical' merit.
Apologies if I interrupted the flow.
British Bike Mechanics September 1988 - Tuning the Norton Domi.
I have that issue if anyone wanted to "borrow" the article.
The ebay link that was put up by someone has disappeared, I've noticed this happening before with useful itemsso is it against official policy on here or is there another personal reason?
After a recent reference to the John Hudson Videos on the message board (3/8" BSC conrod bolts) I was wondering if anything had come of my idea to re-release these on a modern video medium either for sale or for a members only download...I'm pretty sure they would be popular.
Les
If the tapes are going to be reproduced in DVD it would be better if the this is done from the orriginal masters and should be arranged by the club to avoid any copyright issues.
Having raised the matterof the availability of the John Hudson VHS tapes with our Technical Administrator, Tony Ripley, I understand that within the next few days the Engine Strip DVD should appear in the NOC shop. If this has sufficient interest then the Gearbox Strip videowill apparently alsobe converted to DVD and made avialable.
So keep an eye on the web shop.
Excellent Pete...Many Thanks and very well done.....I look forward to their release...hopefully not too expensive....squirm...Smile
Would it be possible to scan it and put it up as a pdf please
"I understand that within the next few days the Engine Strip DVD should appear in the NOC shop"
DVD is in the NOC shop now..
Previously Pete McDermott wrote:
Having raised the matterof the availability of the John Hudson VHS tapes with our Technical Administrator, Tony Ripley, I understand that within the next few days the Engine Strip DVD should appear in the NOC shop. If this has sufficient interest then the Gearbox Strip videowill apparently alsobe converted to DVD and made available.
G'day Pete,
Just ordered a JH (RIP) âEngine Strip" DVD; while I still have both VHS tapes I have noâ serviceable' VHS player so would definitely like a JH Gearbox DVD copy!
I have taken VHS tape data off to DVD and the results were not very encouraging.
Regards Steve.
May I make another suggestion please? Although, as yet, I have not bought a copy myself as I want to include it when I put together a larger order on parts, I was thinking it might be a good idea, in order to sell more copies, to send off a disc (with SAE for their return) to the most popular classic motorcycle publications for them to either review or at least mention it in there news articles. I am thinking of publications such as Old Bike Mart, Classic Bike, Classic Bike Review...and the like. I am sure this will lead to more sales and help make a slightly bigger return on the NOC's outlay......Les
Having already got the Mick Hemmings DVD I thought they were a bit expensive when you add the VAT and Postage.
