Rebore mileage.
Hi chaps.
I've now decided to completely renovate my Model 7 as it would not be practical to get it back on the road as a runner, it's in far toopoor a state.
Whipped off the head yesterday to find it has +20 thou pistons. The bore looks good with very little ridge (Mostly carbon) at the top.
QUESTION: What mileage would be expected for a Norton 500 twin to cover before it's first rebore was required?
I know this can vary, but with average use, average dusty roads and average usage with oils that were available in the 50's and 60's, there must be somepersonnal experience with club members as to what mileage they found a rebore necessary.
Would 35K miles seem about right? I would imagine the lack of air filter does not help in extending the mileage.
Many thanks
Regards.
Les H
Hi Les,
Mine was on +010 at 30,212 miles but this was badly worn and the bores pitted; you could see where the rings had been sat as the acid released when old oil decomposes had made a mess of both bores (this is why you should turn them over regularly when in store!) yet it did run sweetly. At least it did until last timeIrode it round the field when it developed a severe misfire then died completely. 40 years off the road and a BAD attempt at re-commissioning 9 years ago by a past owner who failed to find a seized pressure relief valve and an oil pump that did not do much (both of which I had diagnosed and sorted BEFORE trying to ride it). What didnât help was the slip ring in the magneto had a canyon worn in the Bakelite while the metal contact was at normal height!
The moral here is that it may run after decades of standing BUT it runs a high chance of serious damage if you just use it without the proper checks, compression is NOT a good indication of how good the engine is and nor is the fact the mag seems to have a good spark! You can cook a newly rebuilt engine with a duff mag as if it does not spark at the correct temperature your engine will overheat and be a pig to start when hot.
If you do need to do a rebore DO NOT use replica pistons as one likes to seize and the other to fall apart. I got lucky and found some new old stock Hepoliteâs for mine, they are out there!
If your trying to estimate the mileage on your bike, this is a difficult way to do it on such an old bike. Rebores are a funny thing. Considering normal running wear and not a blow up....I know quite a few people who will pull an engine down and get it rebored because they have the engine apart. They will very often have absolutely no idea why they are getting a rebore done other than they think it's the right thing to do. I've seen people waste the metal in their cylinders just so they can say it's been rebored with new pistons. Did they measure it up? Did they know what they were looking at? Did they know why they did what they did? Many engines cop a rebore way before they really need it. All going well if you could get at least 35k out of your cylinders before a rebore, then I think this is not a bad figure. If your bore looks good, then you might estimate it's half way along it's 35K, so are you estimating the bikes done up around 50 something K. How does the rest of the bike look.
The best way to check the bores is to measure them for ovality & taper, measure the pistons & inspect the rings for wear, then you know where your at and you can make the right decision.
Regarding pistons, mmmm, I've known so many people who go to great lengths to get NOS pistons and have trouble. They come up with pistons in tatty 50 year old boxes and are quite proud to have found the genuine original item. It's a lottery. The damn things have probably been kicking around the shop, shifted from one spot to another dropped on the floor, bought & sold as businesses have gone to the wall over the years. I've got my doubts about them. I've certainly seen a few blown up engines with you beut NOS pistons!! I've seen JP pistons bagged out on this forum a few times, but I've had JP pistons in my Commando for 15 years, I've a JP piston in my Model 18 and another in my 16H. I have had no trouble from them and I don't go easy on them either. Compare an old piston with a doubtful storage history, 50 year old metal technology, to a brand new freshly made item with current metal and machining technology. It's the piston that does all the work in the motor....it's your choice.
Bob
Hi James and Robert.
Thanks for your replies, and in both cases it seems you are saying that 35K miles is not way to little a mileage.
I'll put you in the picture a little more. The bikes speedo, looks original and works, it looks"welded" into the fork crown with the "melted with age" rubber sealing band, so I'm pretty sure it is the original one (OK it could have been replaced 40 years ago, but I don't think it has been). The mileage showing is coming up to 39 K miles. With this sort of mileage I have to say I was imagining that it would be on it's original pistons, but no, it has a +20 thou set covered with thick but softish carbon. I would say the carbon is from an over rich carb setting rather than oil as the plugs were also quite sooty.The bore only shows 1.5 thou difference top to bottom and the pistons look good with no blow by.
From experience I would say they have covered perhaps 5-8K miles but impossible to say accurately. So it seems the bike was rebored at 30K miles which does seem a liitle on the short side for a 4 stroke.
Other engine wear signs: Cam tips look good with very little wear, although the cam followers do show a small wear indent line right in the centre and across the follower. This is the area of max pressure. I cannot recall any signs of wear like this on my other dominators, but that was many years ago. Have you any thoughts or knowledge on this please?
Big ends seem ok but I have the bottom end to pull down later.
I agree with you Robert, that sometimes an engine canbe rebored unnecessarily due to it smoking, but this could be a simple case of starting with a wet sump or just the oil control rings not working to well, and only a new set of rings was all that was needed.
I have to say that I was planning to replace and renew every thing in the engine but now I am thinking I should just be sensible and put back most parts if they still have plenty of mileage left. It would save a lot of money, and lessbreaking-in time.
I hope the crank big end journals have little wear, I will just replace the shells, but I'll do the main bearing for sure.
So thanks again, and if you have any views on those cam followers (tappets) I would be interested to hear them.
ATB
Les H
Back "in the day" (i.e. Mods & Rockers in the 1960!) I don't know of anyone who could get away with more than about 15000 miles without a rebore! When I bought my bike at only 14000 miles it had already been bored out to +.030"!This was the result of abysmal or zero maintenance of course - there lies the rub! Change the oil at leastonce year WITHOUT FAIL! It's the same with cars - if you see a smokey car exhaust on any car less than 15 years old it's because of poor maintenence - more specifically, not frequent enough oil changes. That's the cheapest and most effective maintanance you can do on any internal combustion engine.
I once owned a 1986 MkIII Ford Granada and I gave it away to a friend after it had gone over 220,000 miles. It still used no oil and didn't smoke. Conversely the only gauge still working on the dash was the revcounter! Difficult when trying to estimate when you needed petrol! When the anti-lock brake warning light refused to go offI disconnected it! Otherwise it would have failed the MoT! Its oil changewas every 6000 miles. As I was commuting around 600 miles per week, it had new oil and filter every 10 weeks! OK, not perfect maintenance but the dash electronics weren'yt really a DiY job and I was more a mechanic so the engine, gearbox and running gearwere ACE!
The traditional method of using a piston ring in the bore to check the wear is the best indicator - at the top unworn ridge section then near the centre and at the bottom. Any bad scoring means a rebore is essential anyway. Just remember your bike is from the 20th century and was never intended to go long distances at much more than 60 mph! When they opened the first section of the M1 motorway it soon became littered with 1950s cars which had never gone more than 70mph for more than a few seconds at a time in their life!
Back "in the day" etc etc...................
............. Just remember your bike is from the 20th century and was never intended to go long distances at much more than 60 mph! When they opened the first section of the M1 motorway it soon became littered with 1950s cars which had never gone more than 70mph for more than a few seconds at a time in their life!
This is an extremely good point and one I often ponder as I'm belting along on the Big 4. Roads are very different now. When my Big 4 was made in 1950 I don't think it had the opportunity to get along hour after hour on roads that we have today, enabling it to maintain higher speeds for longer times. It does it though, a few more oil leaks on the garage floor at the end of the run!!
Bob
Hi Lionel.
Thanks for your interesting and also amusing reply. It has made me feel even moreconfident on my bikes shown mileage.
I am also from those days and yes, rebores did seem to be something that most owners had to have done and thinking about it mileages must have been quite low when they had them.
Your Ford mileage comparison is also interesting.It is incredible what distances most car engines can achieve without re-bores.
I'm convinced that it is to do with the fact that early bike engines were not fitted with air filters. The amount of dirt sucked in by an engine must result in a massive amount of bore abrasion, compared one burning filtered air.
I have an MZ 301, and recently rebuilt the engine just because the gear lever centralizing spring had broken, even though it had done around 30K miles there were still the honing marks on the barrel and it had no wear to be measured. That bike runs on a 50:1 petrol/ oil ratioâ?virtually no oil compared to a 4 stroke engine, quite amazing reallyâ?but it does have a large paper element air filter!
Regards.
Les H
Service manuals have set dimensions for acceptable wear and make it pretty cut and dry about when parts in an engine need replacing. You do have a service manual for your bike right?
Hi Benjamin.
I think you may have misunderstood the element of my question.
The question I posed was to find out the average mileage normally obtained before a rebore was required so that I could VERIFY THE MILEAGE shown on the speedometer.
At 38K miles I thought this was on the low side but judging from everyoneâs kind replies it now seems acceptable and realistic.
I was NOT asking whether I required a rebore or not, and yes I do have a service manual and yes I also know when a rebore is required by the amount of wear the barrel is showing and piston and ring clearances in reference to the manufacturers data, and a visual inspection.
I hope you can understand the nature of my post now.
Les H
Hi chaps.
Many thanks
Regards.
Les H
i would say it depended on whether dad rode it to work and back or teenager rode it out at night to impress the girls, 500 twin or not, had a 350 nh ariel once , +30 bore when purchased ............... milage recorded 78126 when sold , dads ,till i got to 30 years old, and with very few oil changes too,, just dont thrash it, and it will last and last.
There are several factors whichneed to be considered when attempting to maximize the life of the cylinder bore. Piston speed, choice of lubricant and air filter just to start with.
Engine design and revs affect the speed the piston travels up and down the bore. A long stroke engine tending to have a higher piston speed than a shorter stroke motor of the same capacity. Throw in lots of regular, highengine speed in a long stroke engine and the recipe for fast wear is well under way.
Old and unfiltered oil contains huge amounts of rubbish that will rapidly accelerate the wear problem. Under load it will quickly break down, which in turn can lead to hot spots and then seizure. Likewise, cheap or the wrong grade of oil does not help either. Fit an oil filter kit and change the oil at least every 2000 miles. Always use a high quality oil. The sensible owners use a good 20/50 as this is suitable for most of the year and will out-perform any cheap monograde oil.
Fit anair filter.Even a basic wire mesh type can double the life of the cylinder bore. You need to stop grit from the road being sucked into the bore and basically sand-blasting all the parts.
With no air filter, most engines will struggle after around 20,000 miles and certainly need new rings by then. With all the rights safety features in place, 40,000 miles of bore is easily achievable.
Talk to Commando owners who have owned their bikes for a good length of time and whose engines have always usedboth air and oil filters.Most will admit that the valves guides, main bearings and camshafts usually die before the pistons wear out.
