Hi All, am I better off buying parts through NOC or are they same price as M.Hemmings etc?
Thanks, Paul.
Paul In the main you will…
Hi - I agree with Tony - s…
Hi - I agree with Tony - shop around for the parts you need. Many suppliers such as RGM/Mick Hemmings/Norvil supply sets of parts e,g, 'bottom-end overhaul kit" etc. - These can be a good deal. I find you tend to get better help if you try and source most parts from one supplier. I personally am a fan of RGM Motors- I've used them for years and they've always been helpful and the parts are good.
In the main you will find the NOC spares scheme is aimed at the hard to find / slow moving bits and is not intended to be in competition with the main distributors. This being the case I would suggest that for an 850 which will have to be a late Norton you will get nearlly all you need from the likes of RGM / Mick Hemmings / http://www.andover-norton.co.uk/etc.
