Combat Commando - lowering compression
Has anyone any experience fitting a decompression plate (and gaskets) to their Combat? It would also appear to require longer pushrods. Is that it?
Don't try the thicker aluminium head gasket. It's so soft that it squishes out. The one I tried ended up rubbing the pushrods as it oozed into the pushrod tunnels. I then used a steel compression plate at the barrel crankcase joint which was ok. On reflection I'm not convinced it made that much difference to anything. I didn't adjust the length of the pushrods as I don't think the factory shortened them for the Combat engines.
My Combat head self destructed so I now have a non skimmed head on my Commando and nothing at the base of the barrel.
