12 v wiring loom
does anybody know where i can buy a 12 v loom to convert my 1962 navigator or someone that can make me a full loom
thanks
mike
I do not supply any looms, but I can supply a wiring kit. details are on aoservices.co.uk
This is a set of the right coloured Lucas cables, a set of connectors and some PVC tubing even a list of the cable colours and what they do. This means you wire the bike as you want it. For basic lighting the wiring is as the 6V system, 12V and Electronic ignition details are also on my web site
 Check out their website. It states sales for m/ cycles through TMS  Nottingham but I have bought direct from their site.
A reminder-the original 6V  Wipac system on the Jubilee and Navigator (and some small AJS/M of the  early 60s) had a resistor built into the loom, this resistor, a la Wipac is NOT available. Several looms I have seen have had a very dangerous attempt at this resistor. I can supply a safe resistor. But 12V AND electronic ignition is recommended but Of course an ORIGINAL loom will not incorporate such.
Autosparks are manufacturers and do bespoke work as per Alan's suggestion of incorporating resistor. But by all means keep it local.
By all means go to VWP, but what lengths of what colours will you need? What is the Lucas colour codes for the Wipac loom? What connectors will you need? What sleeving will you need.? AO Kit has the answers.
