Oversize pistons for an 88
First I would like to wish everyone Health and Happiness for 2025 and secondly I would like to ask the people with far more Norton knowledge than me a question.
After using my 88 (1962) throughout last year I was very happy with how it performed and started so easy hot or cold  however I was not happy with the oily exhausts and the plumb of blue smoke when taking off.
So over the Christmas period I took the head and barrel off, the pistons are +0.030" oversize, the rings are all there but the bore is quite worn so I need a rebore, now comes the problem which pistons do I order???? JP and Gardini are the readily available, there are other piston sets available but the sellers don't give the make and after reading various posts on this and other forums I am totally confused and I know at my age I am easily confused so I would would like to hear from any member who has had first hand experience of fitting these and other makes of piston to their machine, good or bad.
The bike is too good a ride to be spoilt by this condition so needs fixing and now is the time to do it.
Many thanks for reading my post.
Kind regards Colin (Swansea)
Probably need to measure the wear . I have re-ringed some used pistons with later better oil rings and it has worked well.
The Gandini and JP pistons are quite good as replacements. Anything new with Hepolite on the box, unless genuine New Old Stock, is likely to be a poorly manufactured copy from East Asia.
The drawback of JP and Gandini is the weight penalty they come with. These pistons often weigh up to 50g more than genuine original Hepolites. Resulting most likely in a need for a crankshaft rebalance.
I'm going through a similar experience with my 88. New to me last year and bought from auction with no history.
ive had the same issues of oil burning and apparent heavy breathing and decided to strip the engine down. Mine was on 20 thou over and the bores were a bit glazed and had previously been honed with sandpaper over some scratches/slight gouges in the bores that you can still feel with a finger nail. It was also very clearly blowing at the head gasket in every direction. This was due to the top of the barrels being far from flat.
I decided to give the barrels a complete freshen up - tidy up the top mating surface and re bore for new pistons. I spoke to the machinist/engine builder/tuner I use and ordered the next size up pistons from Gandini (+40).
i dropped the parts off with him over Christmas and when he looked at it he suggested fitting liners to go back to standard bore as this would allow the spigots to be removed for machining the mating surface. I pointed out that there are a number of posts and bits of info that suggest it's ok to skim the spigots off and run without them. He had a measure up and concluded that the top ring would come out of the bore slightly if this was done so it looks like new liners and standard size pistons are the right option for mine.
anyway - I think what I'm trying to say is it might pay to show the parts to the machinist/engine builder before deciding what to do (unless you do it yourself of course).
I've weighed the original pistons (20 over) and the 40 over Gandinis. The gandinis are lighter by 30g
The Hepolite name is owned by Wassel now. All the new hepolites i,ve come across and fitted are made by JCC in Taiwan and are a very good piston. In my opinion they are better than the original hepolites. Plus they are a ton cheaper than the JP or Gandini
JCC pistons, made in Taiwan are (or have been) sold as JCC, EMGO, Hepolite, Harris and at least one other brand that I can't remember.
As Peter says, they have gained a good reputation for quality and consistency.
I had heard (internet) doubts about some of the rings and circlips that suppliers boxed these pistons up with, but not recently.  It's hard to be sure what's what, because ring problems are often caused by the fitter or the borer.
It's just occurred to me that you're looking for a decent piston to go to from the current +30 size and I probably need to change mine back to standard. I've emailed Andover to see if they will take my +40 Gandinis back (boxes have been opened) but no reply yet. Yours for 10% less than what I paid if you're interested?
weight is approx 290g including rings, pin and circlips.
I`ve been doing my 88 over the last year and was quite new and lost to the Norton engines. I had the Gandini pistons as advised by my Reborer . I did find that they needed some work to match there weight though.
Hi
Thanks to all who replied to my query and apologies for not getting back to you sooner but I had a family issue to deal with which delayed my reply.
Have done some measurements and there is around 0.008" wear in the both bores, right hand could be a little more. as it's on plus 030" now I wouldn't tempt to rebore to plus 040" as not enough material so will go for plus 0.060" pistons.
I am going to look for original Hepolite NOS +0.060 pistons, rings and pin then rebore to suit, I have got one piston already so I will be placing a few adverts here and elsewhere in my search, I would except any hand piston as I will machine the valve pockets to suit which seems common now.
It may take some time to find the but it is Winter so there is no rush to complete, thanks again to all, health and happiness to everyone for 2025
Regards Colin
Also worth checking the valve guides. It is not uncommon for them to be loose in the head which also is a source of smoking.
Thanks for the reply Paul, I have time on my hands as I am still hunting down a LH piston so I will take your advice and check the head over while it's on the bench and see if it needs any work.
Colin
Certainly worth checking valve stem clearance and possible loose valve guide.  Valve guide hole in head can be damaged if an old guide is driven out cold and/or with carbon on it.  Then oil gets sucked down the inlet...
You could go one oversize bigger and fit 650 pistons. I have done that in the past.
I didn't even know that could be done Gordon but I shall keep it in mind if all else fails, thank you
After three months of searching for NOS hepolite pistons I gave up and bought Gandini pistons from Andover Norton, had the cylinder bored out locally (+.060") and rebuilt the head. Fitted it all together last weekend and fired it up and it ran fine and sounded really good. I will insure it this week and get it out on the road and report back after 500 miles if anyone is interested.
Kind regards Colin
