Selection!
hi 1951 ES2 3rd gear difficult to engage if you nudge the gear change up very slightly then down it will engage or be very  Brutal have changed the selector spring?
... the pawl spring needs to be set so that it is midway between both directions. Assuming it's a laydown box.
New springs are often not the correct shape and need to be bent to give a small clearance on both sides of pawl.
