Magdyno brittle wires
The wires from the magdyno on my 1956 ES2 are no longer flexible and regularity snap where they enter the connecting plug. It is possible that the unit is older than the bike. Any ideas - maybe I could re wire ?
Hi Stuart,
If it is only the wires from the F and D terminals on the dynamo that are brittle, then these can be replaced simply as they both run directly to the F and D terminals on thevoltage regulator.
regards, Ian
