Hi there, I applied petseal to tank, it was clean and dry. The seal took quite a time to dry (several days).
I let it sit a week before fueling up. I now find the small leak is back seeping at the same place. The seal I used was the single type in a tin only. I have ordered a two pack system of petseal. Can I put in the second batch on top of the previous one. I again have drained the tank and it is dry with no loose debris.
Also how do I remove the valve chest on a 1950 16H as I have a small oil leak where the rubber washers meet the head and barrel
Thanks. Robert
