Norton ES2 tyre replacement on an alloy rim
I possess a 1960 ES2 once owned by Alan Shepherd of MZ fame which surprisingly is equipped with alloy rims. The back tyre, Avon SM Mk2 3-5x19 is now due for replacement but I've never taken off nor put on a new tyre on an alloy rim.
Does any member have nice easy methodology for this or some useful tips?
I was thinking of changing to a K70 profile too - anyone have experience of this type of tyre on an ES2?
Regards,
Peter Bolton peterjanetbolton@btinternet.com
Hi Anthony. take thewheel indoorsfor 1/2 into a warm room. Rubber becomes much softer when warm and this helps a great deal. You could try running boiling water over the tyres to also soften them too.
Take out the valve of the inner tube and make sure all the air is out.
The real secret is making sure you have the tyre right into the rim well. This allows the tyre to be lifted higher off the rim at the levering position. I have sometimes used a couple or three wood workers G clamps to squash the tyreat the opposite position to where you are levering. When you have the tyre really deeply seated in the well you will feel the extra height available to lever up.
Lubricate the tyre bead edge with lubricant. Swarfega is very good. Use for removal and fitting.
Buy and use the NYLON rim protectors, they come as a pair. You should use the shortest levers that you can just manage to slip the tyre dead over the rim edge to start with and then work around the rim.. You may need them for the last inch or two when fitting the new tyre.
When you have the new tyre on, it is sometimes difficult to get the valve in first on the inner tube as you cannot get your fingers to reach under the tyre edge.
It occured to me one day you can fit and secure a wire to a valve cap and then fit the valve cap. Then the end of the wire can be threaded down into the valve rim hole and then the wire pulled to pull in the tube!. The rest of the tube should be positioned in and inflated very slightly to remove kinks.
With a warm new tyre plenty of lubricant, and theG clamps allowing the tyre to sit deeply in the rim well, you should be able to get the new tyre nearly all the way with just wrist work and maybe only the last couple of inches will require levers.
Good luck
Les H
OOOOOPS and cringe!!! Forget that little idea about pulling the valve through using a wire on the valve cap....yes you all spotted it...the valve cap won't pull through the rim hole!
I thought of the idea a year ago but had forgotten thatit wouldn't work for the reason I have just said.
You could though screw something shortINTO the valvethread but I don't know what thread size it isso forget it. I'll get my coat.
BTW. the G clamps are for squashing the width of the tyre to enable them to sink into the wheel well, not to force them directly into the well.
CU
Les
Dear Les,
Thank you very much for all that sound advice - I can see the logic in it throughout. I've got the g-clamps butwhere might I buy the nylon rim protectors you mentionor do you perhaps have a photograph of themthat you could send to my personal e-mail address?
Regards,
Dear Les,
Bought the protectors, followed your advice to the letter and the tyre came off without my marking the rim. The tyre might arrive tomorrow so in the meantime I've been removing some of the aluminium oxide exposed in the inner rim under the rim tape (which has been scrapped).
I might not have such an easy time of it in the next few days because as you said the tyre has to really sit down in the rim to enable correct fitting of the tube.
So far so good though...
Regards,
Dear Les,
Regards,
Just a point to think about. Don't be tempted to use washing up liquid to lubricate the tyres, particularly on alloy rims. It contains a high level of salt and will sit there inside your wheel eating it's way out. Try and fit the tyre without any lube, or proper tyre lube as used by the professionals. I'm not sure about swarfega.
Dave Evans
Dear Les & Dave,
Eureka! All done and dusted!
Tyre came today so put a smidgin of WD40 inside the rim to prevent corrosion then smeared the tyre bead with some vaseline after leaving it in the sunshine which made it very hot and it went on like a dream. Used the rim protectors at the last minute just to ease the tyre on. I have never ever got a tyre on a rim so fast so many thanks for the sound advice.
Regards,
Dear Les,
Regards,
Dave Evans
When one has worn one's fingers out pressing on the tyre nearly all the way round and needs to lever the last few inches, it is possible when fitting the rim protector to drop it inside the tyre. Particularly with valanced rims, it can be hard to retrieve without undoing some the previous hard work - unless there is a bit of string attached!
http://cgi.ebay.co.uk/MOTORCYCLE-MOTORBIKE-TYRE-CAR-ALLOY-WHEEL-RIM-PROTECTOR-/220749627254?pt=UK_Motorcycle_Parts&hash=item3365b3ff76
Never really understood what the chord is for!
Les
