frame enquiry
Hi - i am a new member and about to start rebuild of a 1960 dommie 99 with no v5 for it. Its likely to take sometime as i have several other projects to finish first and many items still to buy for the dommie, so its too early to get a dating cert (as it will expire before i can use it), in the meantime is it possible to find out if my frame was a uk bike or an export.  Thanks
Hi Sean,
Dating letters are only valid for 12 months and we cannot issue a letter until the bike is complete. So to answer your question, build the bike then go onto this website under the records section and apply for a NOC2. Paul Nicholls is the Twins Officer but if you just want to confirm that your frame and engine numbers are correct, email either myself or Paul Nicholls and we will gladly check it out for you.
Kind regards,
Paul Watkins
Records Officer
Post-War singles
Email: recordpostwar@nortonownersclub.org
