Hi all I'm looking at replacing the wiring loom on my es2 iv seen a lucas one on ebay does anyone know of anyone that's had a loom off ebay and if they are any good
thanks Steve
Lucas wiring looms
Hi Ian thanks I will order…
Hi Ian
thanks I will order one then it does look the part the wiring on my Es2 looks suspicious so im sure it willtake longer to sort than replace
thanks Steve
Harness type
Not sure what year your ES2 is so make sure you get the one which matches your horn location.
Horn mount
Hi Ian
yes it looks the same horn mount on saddle mounts
So should be ok
thanks Steve
I've used several of the Wassall "Lucas" wiring looms (in both red and green boxes) and all have fitted perfectly both on single and twin cylinder models.
