I was sure I had one, but nowhere to be found.
So, if anyone has one lying around I'd be grateful you would measure the length of the large diameter section, as identified in pic below. I.e. the dimension you'd need to make a spacer the same length.
Thanks.
20mm Regards Tony
20mm
