Mk3 rear wheel stub axle measurement
I was sure I had one, but nowhere to be found.
So, if anyone has one lying around I'd be grateful you would measure the length of the large diameter section, as identified in pic below. I.e. the dimension you'd need to make a spacer the same length.
Thanks.
Mk3 stub axle
It was a tossup whether they'd have gone for 3/4" (19.05mm) or 20mm.
