Will it work on a 99 ?
I have a  fully restored carb by Martyn Bratby ,beutifully machined . The issue is that its a 389  with a 1 1/8"  bore .  The standard carb is 1 1/16" .  Its not a simple change as other components will need a little work. The bike is fitted with  a filter system and Higher than std comp pistons from a 650. . What do you think?.
No trouble at all. You may have to play about with choke and throttle cable lengths  but it will work great. You didn't mention air filter - obviously if you have one for the 376 body it will not fit the 389 body directly.  Try a 250 main jet, 25 pilot , 106 needle jet  and posn 4 on the needle. I had those settings on a low tuned T110.   Good luck Bob, Howard
Hi Robert, If the 389 has a standard Atlas No.3 slide, you will possibly find it will run a bit rich at part throttle- my 650 certainly did (but I have twin 389's on my 650). I'm sure I have similar settings as Howard mentioned,  but I had to go to 3.5 slides to get it to run well.  Regards, George
I think mine has a 31/2 slide so should work .Will probably still run a bit rich due to the very close tollerances its been built with.
