Which lift table for a Commando.
Hello, please can you share thoughts about table lifts. I am looking at Sealey 365 or Clarke CML3 to lift a Commando. I like the idea of the different lift heights of the Sealey, but the platform looks short and the rear wheel hang off the back of the table. The Clarke looks like it has a longer platform but only one lift height. Any advice from your experiences (wheel clamping: strapping down: access to the bike: using main stand, etc.) would be welcome. Thank you, MarkO
...is vital whatever you use. Too many downsides to any fall!!!
one that allows easy (either) wheel removal while strapped down on centre stand is good.
I have the https://www.machinemart.co.uk/p/cml3-hydraulic-motorcylce-lift/ and it does have 2 lift heights.
Very happy with it.
I also have the MM table .. its big. A good space is needed. Rear wheel removal is provided with a panel that needs the centerstand to hold the wheel off ground.Front wheel removal needs some inginuity. Extra ground stops are needed to provide stability to the table when down otherwise someone accidentally standing on the table can upset things.. Ramp surface needs painting with non slip paint for when oily . Table has pointed corners that would be better rounded .
