Hi all, i am looking to change the seat on my roadster, will an interstate seat fit? its an early type frame that the centre stand bolts to the frame. thanks in advance
No, the Interstate seat base…
Yes, if you look at…
Yes, if you look at photographs of interstates you will see that the seat sits further back on the frame rails. Of course John & I are assuming that you have a roadster tank!
(for reference ! have a roadster with an interstate tank & seat, that works without a problem ;-) )
roadster seat
Hi , thanks for the info, not sure which tank is fitted, the seat is not original, will keep an eye out for an original seat.
Stuart, here's a side by…
Stuart, here's a side by side comparison, you can clearly see the difference in the Interstate/Roadster seat positions.
https://www.accessnorton.com/NortonCommando/roadster-vs-interstate.30580/page-3
No, the Interstate seat base has depressions for the oil cap, the rear mudguard and is flat. Pull it forward and it will misalign on these. You need a roadster seat, it also has a bend in it to raise at the mudguard.
