Something i have not seen before ,wear in the steel ? bush. Thought I was the only one using a rear brake !, I have always used it as its the only way followers knew you were braking and I was always going silly fast and needed brakes and downchanges to save the day. I think a newer brake plate is the easy option ,dont think any bushing availiable ?.
It's easy to machine it…
It's easy to machine it round again and make it bigger to take an oilite bush.....Then fit the old cam or buy a new one if it's worn as well. Cheers, Howard
