Hi. 1973 750 with hydraulic front brake. I have drained down the master cylinder to replace hose etc. I removed the lever to paint the master cylinder but now I am having trouble refitting the lever. I cannot seem to get the master piston to depress enough to fit the pivot bolt. If I get it close I think the piston is so depressed that the brake wont operate anyway. Can a piston get stuck? Should I try and rebuild the master cylinder? Or, is there a knack I am missing? Thanks.
You should be able to push…
Thanks very much. I have…
Thanks very much. I have connected hose, bt no fluid, and switch so that's a possibility. New seals may be in order as you say. Just had a cataract op so will try in a day or so!
I will dismantle and…
I will dismantle and investigate out of interest but I have decided to take the opportunity of upgrading to the Andover 13mm option. Thanks again for your help.
FRONT BRAKE LEVER
It's a very good choice, and will significantly improve braking, as it's the original master cylinder that's mainly responsible for very poor braking.
You should be able to push the piston in with your finger. So, normally, you will push the heel of the lever against the end of the piston and drop the pivot bolt in.
A couple of possibilities occur to me:
