After sending the cylinders and heads of our 1959 De-Luxe Jubilee off for Soda Cleaning, Parcel Farce have managed to lose them on return! ("they've gone missing, the Sender will have to claim....".
Two Issues here:
1. In the likely event that they've gone forever, has anyone a cylinder and head set for sale?
2. Don't use a Supplier that has Parcel Force as their Carrier.
thanks
Phil
Hello Phillip, there are a…
Thanks for the info Kelvin…
Thanks for the info Kelvin - I hope that those heads on ebay aren't mine!
cheers
Phil
Hello Phillip, there are a pair of heads on ebay starting bit at £95, done up ready for fitting, i bought two new barrels from the spares scheme, they are £20 each, they only have the left hand side so i had to modify the fins to get the left barrel to fit on the right hand side of the engine so it clears the timing case, its a very easy job to get done, the only problem is that they dont have the inserts fittedfor the cam rocker rod.
Cheers Kelvin.
