ES2 gearbox oil leak
My ES2 has been leaking oil Gearbox and kickstart shaftfrom the kickstart shaft.
Upon investigation, there appears to be either a cork washer or some "O" rings missing.
The attached pics shows the missing cork washer, which I have replaced, and possibly some oil "O" rings  for the machined grooves on the kickstart shaft.
Can anyone confirm if this is correct?
Thks
Bruce
They normally just have a cork washer which doesn’t do much, I fitted “o” rings in the two grooves which has stopped the leak.
john
