Hi can anyone help me with setting the pressure on the check valve located in the timing cover
please.
The felt washer on the gear box shaft, is this fitted on the inside of the chaincase behind the clutch assy. None of my drawings show where it has to go, but it shows on the parts list.
Grateful if you could advise please.
Len Adams
Dominator Model 7 spare parts 1949-1950.pdf
chaincase felt
My wideline featherbed '99 has a felt washer behind the clutch. It is actually fitted in between 2 parts of the rear chaincase. ie in between a small circular plate rivetted to the inside of the main rear case. The inner one has to slide very slightly to centralise the felt when you adjust the primary chain.
Here is a page from the above parts list which might help,
Stan
