con rod lengths
There is an advert in the wanted section for a model 19 con rod measuring 7.5 inches between centres of big end and small end when checking my spares iv found a norton singles crank assy 8 inches between centres does anybody know what bike this belongs to
I'm sure this will have been posted before but here goes:
6.1/2" con rod is for M50 with 88mm stroke
7" con rod is for ES2 and presumably M18 with 100mm stroke
7.1/2" con rod is for 19R and 19S with 113mm stroke
8" con rod is for 16H with 100mm stroke and also for Big 4 with 113mm stroke
(I'm pretty certain that pre-war 633cc Big 4 also used the 8" long rod for 120mm stroke)
The OHV engines always had a slightly bigger crankpin and thinner con rod liner than the SV engines which accommodated additional full complement rollers)
AJS / Matchless con rods are slightly wider and stronger around the big end eye
7.3/8" for both 350 and 500 until early 50's and then changed to 6.7/8"
(I use 7.3/8" rods with INA type big ends in both my 19S road bike engines and also in the old 19R racing outfit back in the 80's)
Thanks for your post on con rod lengths its cleared up something thats  been puzzling me about a crank that I have which I thought was off a big four but now I know is off a 16H
        Regards G.Roberts
The website encountered an unexpected error. Please try again later.
