Looking at buying this bike , I have a model 18 bitsa I keep in Ireland , but I know nothing about internationals , so please let me know what's right and what looks wrong, I will get better pictures
this week and the engine number and frame number .
1939 Inter.
There are a few differences…
There are a few differences between the frames of the ES2 and International. It's not easy to tell from the picture. Hardly anyone will know or care, but it perhaps might affect price slightly. Except that not a lot are sold so there is no fixed guide price! Obviously it looks very pretty.
Richard has mentioned the forks. The lengths of 16H and Inter forks are identical, so they won't affect the ride, even though the Inter has a larger front wheel (21" instead of 19") The Inter did not have the same interchangeable front and rear wheels, so the front hub was a bit lighter and narrower, and brake adjuster was high up. Inters had 20" rear wheels, but lots have been changed to 19" with a larger tyre because 20" rim size rear tyres are hard to find (impossible?)
ES2 rear suspension plungers were vertical, but Inter ones sloped forward at the top. This was because the Inter had lower ground clearance and the engine sat lower, so a line bisecting the line of the plungers had to slope down to be in line with the gearbox main shaft. A side view will confirm which is which. It won't make much (if any) practical difference. Inter brake plates were chrome plated. That gives you the excuse to make it even shinier than it already is!
I wouldn't let any of that put you off unless you are absolutely obsessive and want to chase concours cups at a venue where the judges will know (which is unlikely even in UK).
They are great fun to ride, but don't wear a white suit. It takes a lot of expertise (and I suspect luck) to stop the open valve gear from splashing oil about.
The fuel tanks does not have the 'pie crust' soldered lower edge. I suspect welded tanks were made in late 30's. Mine is also welded, so yours isn't unique. Its painted in 'road' not 'racing' pattern. That appears to have been normal for road bikes, even though lots of owners painted them with the broad black racing pattern lines.
Mechanical condition is important. An engine rebuild is not for the faint hearted with no prior experience.
Pretty much every Inter is different today...
White suit
Welcome to the NOC , personally I think you SHOULD wear a white suit, it would help with the heat in Texas.
There are many experts in the NOC who will make sure you don't buy a pig in a poke but as I often say a pig in a poke is better than no pig at all ( unless you pay to much for it )
Good luck with your international buying and hopefully see you on it soon !
Got the numbers
Engine number is CS 79643. Any idea what the CS stands for ? Camshaft ?
frame 83670 .
i will take more pictures tomorrow.
The forks appear to be 16H or model 18 due to where the front brake adjuster is.
CS would mean a CS1 when it…
CS would mean a CS1 when it left the factory, not an International. Much the same engine but with cams, carburettor and gear ratios set up for road use rather than racing. Lots of CS1 were tuned for racing.
Visible differences include;
Inters has TT carb. No tickover (unless modified).
Inters had parallel front forks. The four girder fork spindles are the same length. I imagine yours are correct for CS1, but someone else might know.
CS1 had 19" rims front and rear. Probably interchangeable wheels.
CS1 carburettor inlet was horizontal, not sloping down.
Inters had gear ratios stamped on the back face of the box. 2.12 1.33 1.1 1
CS1 might be stamped 2.98 1.61 1.21 1
CS1 don't seem to have been made in the same numbers as Internationals. But their gear ratios are more logical for the road. Very similar to Commando and Dominator.
Frame and engine numbers.
Hi Peter,
The engine number dates from 1937 and the frame number would be late 1938. I'm quite sure this frame is post-war as the 1939 frames did not have centre stands. It is possible this number has been sourced from the factory records and applied to this machine. The girder forks cannot be identified by the brake cable lug alone as these changed a couple of times during the 1930s period. The forks on this bike can be identified by the the headlamp brackets as these were only used for the 1946 season and never fitted to Inters. These would have been the splayed type which makes me think they could have been made parallel professionally or simply squeezed, bending the lower tubes. These do not have the Andre damper as there is no anchorage on the post-war frames. The tanks look to be post-war as is the front wheel.
If you are happy with the bike as it is, make sure everything is above board as there are a lot of scammed bikes and parts appearing on the internet these days.
Great information
Thanks , learning a lot , here's another one that just sold 1939 with a center stand and frame number a few after the one I am looking at .
If you go to "vintagenorton"…
If you go to "vintagenorton" Web site, you will find downloadable copies of pre WW2 Norton brochures. Pictures can't always be trusted in all details but they should be helpful. There are also various downloadable technical files.
When optional plungers arrived in 1938, the rear drop down stand was discontinued. So centre stands (they described as 'prop stand') had to be used instead. The 'prop stand' had already appeared on rigid frame bikes a few years earlier.
Someone else might confirm when the forward facing 'suicide stand' was fitted.
Suicide stand.
Hi Peter/David,
It looks like someone is making a business of making 1939 Inters ??
I, and many others, cannot understand why the 1939 frames had the forward facing rear stand when the older type plunger frame had a conventional centre stand. This was an Edgar Franks design and was fitted to all, new for the 1939 season, plunger frames including the Manx Grand Prix racers leaping over Ballaugh Bridge in the Isle of Man ! These were fitted from September 1938 until the out-break of WW2 a year later. I have attached photos of my 1939 stand FYI.
Perhaps the reason for the…
Perhaps the reason for the new stand was that the original centre prop stand was only suitable for parking on a flat floor? My 1937 16H one is not very secure on even slightly uneven ground. It doesn't lift the bike off its wheels, so is no help when changing a tyre.
I think you (Richard) were correct in your post in 2019...the sloping plungers keep the wheel movement at right angles to the line through the sprocket centres of the rear chain because frame is lower at the front than ES2.
Hi Peter,
Welcome to the NOC. I can see the forks are from a 1946 Model 18 or 16H. There are many of these bikes built up from spare non original parts, so you need to factor this in to the asking price. A full photo from each side will help identify how original this is. I may have seen this bike before, is it in the USA ?
