I need to replace a leaking top gasket on my 2017, 961 sport, the first two questions I have are, where can I obtain a gasket and secondly, once I have taken the tank off the bike can the rocker gasket be replaced with the engine in. I guess it will become apparent once I start but knowing the answer to the second question will determine when I start !
I stock the Thiel Motorsport…
Excellent advice, thank you…
Excellent advice, thank you. How do I order the gasket from you ?
Hi Alan I'll check the price…
Hi Alan
I'll check the price later for you, including postage. I'm not a mail order business, the stock I mainly buy in for my own in-house customers....but I do try and help out where I can.
I've also got some stock of the original Norton gaskets...I can do those cheaper than the Thiel gaskets, but I won't use them on mine or my customers bikes...
I stock the Thiel Motorsport equivalent.
And yes, remove tank, battery, battery box and you can remove the rocker box with engine in situ. It's a bit of a fiddle though.
