Really struggling to release the lock nut on the clutch adjuster screw even with the chain case outer removed!
Any suggestions welcomed.
TIA
give it a sharp knock with a…
Thanks Tony I will nip to…
Thanks Tony
I will nip to Machine Mart and pick one up.
Thank you-all sorted
Usually a sharp tap on a…
Usually a sharp tap on a long tee bar and a good fitting 1/2" drive socket will work when a steady pressure fails . put the box in top gear and a spanner on the rear brake drum lever nut ( you do have three hands dont you !!.)
give it a sharp knock with a impact gun . just a quick blip
