Con Rods
Can anyone tell me the length between centres of 88 & 99 Con Rods?
I have a spare rod somewhere ,  you are probably aware that 88 and 99 rods are the same . length. The distance between centers should be the same ,but there may  be a very small varience as they are prone to stretching when well used. I measured some NOS ones and found differences in the big end sizes.  Interesting.  I will look for the rod.
The 1.6050 measurement is helpfull  for checking used rods  for ovality , I suspect these rods used std Norton type shells.
