Can anyone tell me the length between centres of 88 & 99 Con Rods?
I have a spare rod somewhere…
Looks like 153mm or perhaps…
Looks like 153mm or perhaps 6 inches would be likely , back in the days of "proper" measurements.
So its 6 inches then.
So its 6 inches then. What shells did you use.?.
After much searching thro…
After much searching thro the records I think they came from Norvil It was a long time ago!
Laurence
The 1.6050 measurement is…
The 1.6050 measurement is helpfull for checking used rods for ovality , I suspect these rods used std Norton type shells.
I have a spare rod somewhere , you are probably aware that 88 and 99 rods are the same . length. The distance between centers should be the same ,but there may be a very small varience as they are prone to stretching when well used. I measured some NOS ones and found differences in the big end sizes. Interesting. I will look for the rod.
