Norton Slimline Featherbed Handlebars
I have been searching for the right and correct handlebars for my Norton Dominator with Slimline frame. Most commonly the straight Handlebars fitted but I do come across low rise Handlebars fitted too. Which one is factory original? And where can I find the correct low rise Handlebars IF straight Handlebars are not factory original?
Official records say My Slimline Dominator was despatched from factory with straight handlebars and ball end levers.
RGM Have a good handlebar choice. Roger is very helpful and knowledgeable . I have straight bars. on a 1960 dominator 99
In reply to by tony_gill
Yes, I just contacted RGM but the handlebar which is closed to the original (low rise handlebar) is out of stock unfortunately. But I still prefer the old original handlebars rather then a copy/reproduction
My 60 and 61  Dommies came  with the standard  low rise bars   that had  drilled and tapped holes for the dip switch .  I think the straight bars were optional , I dislike straights because they can give the cables a hard life  on the fork nuts if you try for an organomic angle that gives a good clutch action. You can improve matters by fitting some bar risers  as on our Atlas.
Hi Robert, I have straights on my 1962 650SS and raised the bars by simply buying a new set of clamps, remove the old top clamp, turn the new clamp upside down, and place under the handle bar. The bar is now secured with 4 longer BSF bolts. Both brake and clutch cables probably have 5mm clearance with the top nut.
Roger
and reverse one and place is below the handle bar
You can usually tell orriginal bars because they will have the drilled and tapped holes for the horn/dip switch. When pattern /aftermarket bars are fitted owners often changed the switch to the clamp on ones. However I think  i used my orriginal bars on another make of bike (!! ) and drilled and tapped some new  bars for my 99. I think the rise is about 2" and you are probably better off looking at old road test photos  to  judge the shape you need if orriginality is your aim.Avoid alloy or stainless steel as they are likely to snap off in a minor spill  wheras  good old plated steel bars just bend a little and get you home.
I will have to find some random  child to show me how to  post a photo.  If you google Norton Dominator 99 and  click on pictures you will get a good selection.  I should have mastered this photo stuff years ago ,so will try, don't hold your breath !!.   Look in NOC shop page 9 ,part no 19405  .
All the UK SS and Atlas Models had the straight type of handlebars unless there was a request for others.  The US market had some different types but they don't complement fast riding.  Good luck, Howard
Hi Roger thats brilliant ,far too simple !!.   The SS and Atlas in the uk were mostly fitted with "straights"  but here  we are talking about the std 88 and 99 which unless specified came with the same low rise bars as the model 50 and ES2  and were designed for touring and commuting , which is why they often got changed to Ace bars  in the mid 1960's . Exactly what i did ,along with alloy guards, twin carbs, ballend levers and  chequered tape.
If it’s any help these are what handlebars I have on my ‘68 Atlas, not particularly sporty but certainly gives a comfortable riding position. Due to the age of the bike I’m thinking might be same as early Commando, cheers Simon
