Hi
Does anyone know, (or could point me in a direction to find out), what the thread is in the Jet block of a 376 monobloc?
The jet holder screws in a couple of turns then starts to get tight, I 'm not keen on using anything above finger torque as I assume the the jet holder is the softer material and will easily damage
Also anyone have experience of how tight a fit the jet block should be in the carb body? Mine needed to be pressed out and even after cleaning looks as though it is going to be a tight fit going back in, yet I saw some video of a carb strip and the guy just pushed the jet block out with his fingers?
Any help much appreciated
I have recently had to pass…
Paul I recently bought a…
I recently bought a ES2 with a 376/3 monoblock fitted. It is in poor condition and the bike would only run (for a while) on full choke.
I contacted Burlen Fuel Systems (01722 412500) and spoke to their Technical guy who was very helpful. He told me my carb was designed for an Ariel350 and I should be using an Amal 376/17 for my ES2.
It might be worth giving them a ring?
Cheers Michael, mine is a…
Cheers Michael, mine is a 376/67 which is correct for my 1960 99
I've been getting my carb spares from Burlen and they seem a pretty reliable company, I will definitely give them a call if I experience any more issues
looking up the data
I looked at the Monobloc data pages thoughtfully provided on Jampot Archives:
http://archives.jampot.dk/technical/Carburation/Amal_Monobloc__numbers_type_and_use.pdf
It lists the 376/3 as being 1" bore, for a BSA B31, whereas the ES2 body is stamped 376/17 and has a 1 1/16" carburetor. As long as the body you are looking at is the right bore size, and is not excessively worn, it will do. The /?? number is just a build specification. Change one small detail, and it got a different build number at Amal. Make sure the settings are correct for the bike you intend to fit the carb to, and it will be fine - unless your objective is points in a concours competition. Then you will need the 'correct' carburetor body.
If the bike will not run unless the choke is on, it's probably dirty. Strip it and give it a good clean. There may be obstructions in obscure places. One of those is a compensator hole aft of the spray tube. I clean that with a strand from a bicycle control cable, and a magnifying glass so I can see what I am doing. Same goes for the cross drillings in the pilot jet.
I think the tap I used was …
I think the tap I used was 7/16 BSF Bottoming type as its a blind hole in the block . Both carbs would strip and assemble easily but parts were not interchangeable between carbs. Could not see anything wrong with threads but they became interchangeable after a pass with the tap. Very puzzling.
I've just checked...
... a jet holder and it's 19 tpi and 0.435" diameter which I can't find in my Machinery thread book. 19 tpi is usually a pipe or gas thread count but the diameter doesn't correspond to any of those.
Hi Ian, I Have another beat…
Hi Ian, I Have another beat up mono which I have knocked the jet block out of . After this bit of abuse the jet holder was reluctant to re- enter the block A pass thro the jet block with the 7/16 BSF 2nd tap (i don't appear to have a bottom tap ) and the jet holder fits perfectly by hand. It seems that the action of driving a tightish block out of the body is enough to distort the thread a tad.
Interesting...
.... I've tried the 18tpi thread gauge (7/16 BSF) and it "almost" fits whereas the 19 tpi one is much closer. Of course my jet holder is well past its youth so may have distorted over the years. If the BSF tap works then fine....
Note I said jet block in my previous post where I meant jet holder - now corrected. Female threads are very tricky to measure accurately.
Like you Ian I am a bit…
Like you Ian I am a bit mystified by the threads which do appear to run off the gauge slightly.. I'm sure i looked at bsp taps but they did not work either. Perhaps a real expert will step up soon !!.
Threads good now
Cheers for input guys. I can confirm after running a 7/16 BSF 18tpi down the jet block the jet holder screws in sweet
I'm guessing as per Robert's experience the fact I had to press the jet block from the carb body may have distorted the threads a bit
I notice that BSTP (taper)…
I notice that BSTP (taper) threads around that size are 19 tpi , with the same thread form , but 7/16 seems to be a non std size ??. Will we ever know ?. Does it matter anyway !!
I have recently had to pass a tap through the jet block to allow the fitting of a jet holder from an otherwise matching carb. I think the thread tollerance has been changed or something similar. the jet blocks can be a tight fit in the body due to distorsion of the body from overtight fixings and the effect of heat cyckling over the years. I will check what tap i used , i think it was BSF.
