I bought a Jubilee a few years ago, with out looking at the numbers. ( OK Foolishly ) Any way I can not find the frame number, I believe It should on the head stock behind that plate. I can't see it maybe because it has been re-enamelled? Am I right to think that is where it should be? Tim.
Unless it is a deluxe model
Deluxe lightweight frame has a bolted on straight support, unlike the welded on straight support as in Michael's photo above. On deluxe models the frame number is on the RH frame member. On the lower gusset mount for the bolted-on frame brace. Sort of near the hole you can see in Michael's photo.
Thankyou Gentlemen. There it…
Thankyou Gentlemen. There it is and it matches the log book. Perhaps if id ever washed the bike I may have come across it earlier. Tim.
Thats a good result then Tim…
Thats a good result then Tim. Keep us updated with any repairs or mods, all goes into the big pot!
You might also contact Andy Sochanik, he keeps a register of L/W machine details.
Frame Numbers
Thank you Michael - I would sure like to add this bike to my Register.
If I can, I'll upload some frame number examples
The L/W frame number is on the gusset that the pillion footrest mounts, on the R/H frame assembly.
