jubilee + .040 pistons
Hi everyone , I am finding it impossible to find any new + .040" pistons to complete my engine
build . I have some +40 barrels which are very good . Does anyone know of a supplier for +40
pistons . NOC has the +40 rings but no pistons . Any help would be much appreciated .
I “might” have a pair of used +40 pistons in amongst my spares - won’t be sure until I’ve checked (Sunday probably) - would they be any use if I’ve got a reasonable pair?
Bruce
Good afternoon Bruce,
possibly missed the boat but I need a set of +20 pistons and saw this post. Are they still available but any chance?
kind regards Gary Last
Hi Gary - I’m on it but delayed in looking them out at the moment - sorry.  Hopefully next day or two then I’ll send you some pictures
Bruce
This may seem a bit drastic but I had the same problem and in the end I had the cylinders re-lined to take standard pistons.
This company sell standard pistons.
Norton Piston - 249cc OHV (Jubilee 250), Year: 1959-66, STD (classic-motorcycles.co.uk)
I used Meridian Engineering Services in Cambridge to reline the cylinders and they were good and reasonably priced. They can supply the liners.
Home Page (meridianengineservices.co.uk)
Dennis
Hi Dennis , I was allways told jubilee cylinders did not have liners so could not be re-lined.
But if you have had yours done i will have another look ,if they can be re-lined it may be
my only option . Thanks for the name of the company , to be continued .
Colin.
Michael at " Meridian " is a great bloke, helpful and top work.
I used him for my Land Rover Series One engine machining and I built it up, all perfect !
Recommended !
Thankfully i did not know that Jubilee cylinders could not be re-lined before I asked Meridian to do it! They did it and I am pleased with the result.
Dennis
I was all ways told jubilee cylinders did not have liners so could not be re-lined.
That rule that does not exist, it all depends on the strength of the original barrel and nothing to do if it was linered from the beginning or solid.
