Am I missing something? I can't seem to find valve seat inserts on offer from the club, RGM, Norvil or Andover.
I have a DD head with badly pocketed seats. Where can you get new inserts? Is it Serdi that people go to? - if so, does anybody know what the sizes are?
I am not surprised
I have no idea how good of a…
I have no idea how good of a job SRM do, but they seem to have a certain way of doing business, I sent a late dommy head to them for new exhaust valve seats to be fitted.They quoted me just short of £500 which included new inlet seats, and new valves and guides all round. I contacted them and pointed out that I only wanted new exhaust seats fitting, that the inlet ones were ok anyway, and that I could do the rest myself, to which their reply was, more or less "We don't do that, this is how we do it, take it or leave it", so I said leave it and had to pay quite a sum to have my head sent back not done, and found another one with good seats for less than £100.
So if you go to SRM be prepared to have the lot done.
The Atlas seats looked…
The Atlas seats looked pocketed ,but checking the rocker action accross the valve tip. . all looked good. Its clear that the action from new was not the best ,but it seemed that it had fixed itself !. I got my local engineer to unmask the valves with his cutters and it all looks ok. Runs fine too. Later motors got longer valves to improve the action ,so AMC knew something was not the best.
With the Atlas valves now…
With the Atlas valves now set further into the head I did not consider that the valve spring pre-load is a bit reduced. But knowing how the bike is used, tractor fashion ,high revs is never going to happen and the cam will be happy with its easy life in old age.
Thanks for the help guys. I…
I had the barrels resleeved by Andy at Howards, so I might go back to him..
If I am feeling brave (or foolhardy) I might try to remove the old seats.
I seem to remember reading that running a bead of stick weld around the inside shrinks them. If it failed it would at least give Andy a laugh.
It is a S/H eBay head, of unknown provenance, so maybe it has an untraceable oil leak anyway!
Seat removal
Hi Steve,
I spent my working life developing and calibrating car engines, so I have a fair understanding of what is required here.
Personally I wouldn't touch them. Worst case scenario is head gets damaged such that pockets need enlarging deeper or bigger diameter which could/will weaken the head. Please talk to the machine shop you wish to use as to whether this will save you a fortune or make their job harder first!
Of course, it is your head. If you do want to get them out, I suggest you mill out as much of the seat as you can and you might just be lucky that they will crack and fall out. (they are austenitic cast iron if the original seats.)
You never know, you may just find that they aren't as bad as they look and not need changing? Are you looking for that last 1-2 bhp? I remember finding out years ago that the valves and seats will 'pit' quite quickly - certainly within a couple of hours running!
Best Regards,
George
If the seats are badly…
If the seats are badly pocketed then there are 2 cheap fixes worth trying before having the seat renewed.
1. Bigger valves, these will sit further up on the unworn part of the seat and then cut on the bigger diameter.
3. Use a set of 3 angle seat cutters and first cut away on the shallow angle to unshield the valve followed by light cuts and the remaining 2 angles.
The seats are pretty bad,…
The seats are pretty bad, The alloy around them has been partly flowed down to compensate.
So will never be 100%, for sensible money anyhow.
No more impulse purchases for me.
From the "It's an old trick - but it might just work" department:-
Member
- Share
12-19-2005, 03:53 PM
Grind the head of an old valve until it just slides down inside the valve seat. Weld a bead around the inside of the seat. Let cool and then tap the valve stem until it comes out."
Steve
Gorilla weld
Great dodge if it works, very interesting problem to solve if it doesn't...
My PO inserted seats himself…
My PO inserted seats himself. I have no idea now what material he used, but valve grinding paste has no effect whatsoever on them.
I remember he said he heated the head and chilled the seats. But now they are together it must be difficult to heat or cool one without the other. But it might be possible to heat the head as if for valve guide changing, and push a bag of ice...or, better 'dry ice'...in the aperture and see if they just fall out. Where to get dry ice? Pipe freezing kit maybe?
I did a quick calc assuming…
I did a quick calc assuming the coefficient to be 14.4 for the seats and 20 for the head. If anybody knows more about the actual cylinder head alloy used I could do it more accurately.
A low coefficient would have been a driving factor in the choice of head alloy for Norton, and the calc is quite sensitive to this figure (much more so when heating the head and seat together).
Serdi say that their seats are 4 thou to 6.5 thou oversize.
To get the seats to just fall out that implies heating the complete head up to something like 450DegC to 550DegC, relying entirely on the differential expansion.
On the other hand, heating the head up by 200DegC but only allowing the seat to rise by 50DegC would give approximately the same result. A normal oven and a pipe freezing kit might well do the business.
Inserting the new seats should only need an oven if you are quick.
Seriously, I wouldn't try…
Seriously, I wouldn't try it, I think it would work on something like an iron Land-Rover head which were heated in an induction furnace, I believe, then the inserts, chilled in liquid Nitrogen or suchlike, were pressed in, but I believe that the Austenitic seats in Norton heads were put in at the casting stage and have to be machined out.
I seem to recall reading an article by John Hudson many years ago which stated this, and which my local (very experienced and competent) automotive machinist also confirmed when I asked him once if he could do them, to which he replied in the negative.
I think the SERDI process is the best option, it's just a pity that more people don't do it.
changing seats in NHT
The norton head print states the seats are shunk fit.... not cast inI have done several seat changes. The head is oven heated to around 400f and the seat AND the inserting tool are chilled in dry ice (CO2). Using the old guide to guide the insertion tool, you have two rapid hits with the hammer and it better be "home". or take it out and start over.
This is what I do to remove the old seats....
Grind the head of an old valve until it just slides down inside the valve seat. Weld a bead around the inside of the seat. Let cool and then tap the valve stem until it comes out." Steve
Well I stand corrected,…
Well I stand corrected, every day is a schooldays isn't it? Do you make your own replacement seats or use commercially available ones, and if so, where do you get them, to answer the original question?
Print shows T2227
The original alloy is excellent even for eventual no lead fuel. I buy mine from machine shop supply houses. But you buy them in a box of 10. I had gotten the big seats and 1.6 valves from Norvil a long time ago. These industrial supply places are not usually interested in sales to hobbyists.
For my own Lotus elan head I will have to buy +10 and grind them down to +5 my self as they sell standard over sizes only.
Not expecting a positive…
Not expecting a positive result, I typed "Dry Ice" into Amazon, and rather astonishingly they do actually offer it!
10kg £29.
You don't need to worry too much about the sell-by date.
Serdi seem perfectly willing…
Serdi seem perfectly willing to let you set up an account and sell them to you for £5 each (incl VAT), plus £10 courier. They claim to stock 30,000.
How you add them to your basket, using their website, remains a mystery.
Mix and Match
I had the very recessed (85,000 miles) valve seats on my 650SS head changed for unleaded versions 35 years ago. After running the bike for a month the head gasket blew and needed replacing. The head had warped due to the extreme heat used in swopping the seats. This was skimmed to correct but at the same that time the bent head was being sorted it was very obvious that the valve heads were picking up on the new seats and leaving serious craters. The valves were changed for some that had more Chrome in them but these, in turn, took out the valve guides. These were replaced for Colisbro versions and all has well since.
It would be handy if somebody, versed in Metallog,y could list the best combinations of materials for the cylinder head valves, guides and seats to use with unleaded, Ethanol loaded fuel.
NHT VALVE JOBS
1. alloy is RR53B
2. If you heat the head enough to have the seats "drop out" then I would certainly expect the head to twist up.
3. I have yet to need to mill/skim a NHT head. I do check them all, with machinist dye and burnished on my surface plate.
My first combat head was turned over for a valve job to a profe$$ional shop. They of course knew nothing of nortons and promptly ruined the exhaust seats. They happily turned the head back over to me unfinished.
Out of that came one of my sayings...Why pay someone to ruin my stuff when "I" can ruin it for "free".
So after 30 years with thousands of dollars of tools and equipment and a lot of experience on norton heads of my own and club friends I have almost paid off all my equipment and gotten a darn good education.
Here in the US there are still a few (very few) sources for NO-E fuel but for the most part all machine work and parts is done to be E-10 capable.
Only the model 7 iron heads are needing special work.
Interesting about the alloy…
Interesting about the alloy. The tensile strength as cast is relatively low, and it's easy to machine. It's much stronger after heat treatment (artificial aging) but they would surely not have heat treated after machining. But the kind of temperatures people talk about here might well have done the job. You'd end up with a stronger cylinder head, but its crystal structure and thus shape changes....
I couldn't find an expansion…
I couldn't find an expansion coefficient for RR53B. No matter, heating the head and seat together to use differential expansion is clearly impractical.
But achieving a temperature differential of 200DegC-ish looks to be enough with an interference fit of 6 thou.
I can see that dry ice is obviously beneficial, but wouldn't baking in an oven at 275C and using an insertion tool and seat at -5C from a domestic freezer do the job?
As David says, two strikes and you're out.
my measurements 3 Nov 1989
Valve seat room temp 1.505
seat and tool @ dry ice/ -78.5C 1.5025
head room temp 1.4995 @ oven 400f 1.506
seat @ 400f 1.5072
Is it necessary?
I remember many years ago when leaded fuel was being phased out that they said alloy heads (with hardened valve seat inserts) didn't need replacing. This was particularly for car engines like my Jaguars, which have a lot of valves and seats! It may well depend on mileage where seat recession could become a nuisance, but that would be for high mileage (20k+ per year) business and commuter use.
They are unleaded proof out…
They are unleaded proof out the box but if worn or damaged they do need replacing.
So these sound like they do
the 'normal suppliers' don't have them, as it is unlikely anyone outside of a professional concern would have the equipment to change them.
I suggest you contact someone like SRM in Wales who were one of the first to offer 'unleaded seats' for bikes and have a very good reputation in the BSA world and do a lot of Norton stuff too.
https://www.srmclassicbikes.com/engineering Not used them myself and have no connections.
Alternatively, have you asked the shops if they can do it or just looked at the websites? If they can't do it, I'm sure they would advise you on where the good places to go are (and more importantly may well know where to avoid!)
Good Luck!
George
