Dominator 88 inlet hose. Carb to air filter Part 19518
Description of Part Required:-  Hose for air cleaner connection
Model Number required for:-  1960/61 model 88 Standard
Part Number:-         19518
Also used on if known:-          1960/61 models 88 and 99 Standard
Implication of lack of part:-      Cosmetic.
Routes you have tried to acquire the part and response received:-
  1. Andover Norton. No stock for a long time
2.
3.
4.
Do you have a worn or damaged part available as a pattern?
Based on price for similar parts, what would you expect to pay (give range):- £75.00
Comments:-   I would like the proper part not an alternative solution.
                           Others are out there thinking likewise.
Once you have a good idea of the shape and tube size, you could try a rumage in a car scrap yard or auto-jumble.
Norville do a rubber bellows that links a carb ring to the big box filter they sell.  Nor a good fit to the ring.
If anyone has one in whatever condition, I can get it scanned and then 3D printed in black TPU92A which has the same properties as rubber but is printable.
See https://www.stratasys.com/materials/search/fdm-tpu-92a
